Clutch problem....
Clutch problem....
in the past few weeks ive noticed my clutch feels a little different, i first noticed that the pedal lost its stiffness so i thought maybe my clutch was slipping, but it still catches good, rpms dont sky rocket or anything, car accelerates good like usual, the car has around 120k with stock clutch, so i was planning on replacing the clutch to see if that was the problem, and NOW i noticed the pedal went back to being a little stiffer but i can push it down to the ground a bit further then before? clutch still seems to catch good, ANY ADVICE? i did search and didnt really find a good anser
Re: Clutch problem.... (akteamster)
If it is a hydro clutch then check the fluid level. It could possibly be old fluid or air in the system that is causing your erratic engagement.
