What cams are these, ITR, GSR, B17, CTR etc. etc.
Old May 17, 2004 | 01:45 PM
HamiltonRex's Avatar
Default What cams are these, ITR, GSR, B17, CTR etc. etc.
Sorry for the poor quality pics. 2 grooves on the upper part, 1 on the lower.
There supposed to be 98 ITR, They sure dont look it.
They are on the exhaust side btw.
I did a search and they appear to be B17 cams.
QUOTE:
B17a 92/93 GSR cams
Intake cam has 0 engraved rings and 3 protruding rings
Exhaust cam has 1 engraved ring and 3 protruding rings
END OF QUOTE
I have also read that they could be 94-99 Gsr cams. So i dont know what to belive.
Now if these are b17 cams. Is there a possiblity that its a b17 cylinder head? I was trying to distinguish it between the 2nd gen b16 and the ITR. Does the b17 use the same casting? I dont think it is because the stamp on the front which indicates the year it was made is 98. And b17's wherent made in 98 i dont think. So they must have been added.. right??
-Eric
Old May 17, 2004 | 02:00 PM
jamessh1's Avatar
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (HamiltonRex)
what casting is it? pr-3 or p72. p72= gsr head. I had this exact same problem where i got a b16 head with gsr cams off ebay, and was told it was an itr head. Looks like you got ripped off like i did man (although i got $520 USD of the $850 i spent back). The cams most definitely appear to be GSR cams, but to be 100% sure, you should get the lobes measured..........
Old May 17, 2004 | 02:30 PM
jh4db536's Avatar
This is my CTR Intake // ITR Exhaust
notice there are no grooves on the lip, they are on the end of the stick instead.
Old May 17, 2004 | 02:32 PM
AzG35's Avatar
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (jamessh1)
Definately NOT ITR's. They are either B17's or GSR's. My GSR's looked like those, but I've seen some B17's look like those too.
Old May 17, 2004 | 02:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamessh1 &raquo;</TD></TR><TR><TD CLASS="quote">what casting is it? pr-3 or p72. p72= gsr head. I had this exact same problem where i got a b16 head with gsr cams off ebay, and was told it was an itr head. Looks like you got ripped off like i did man (although i got $520 USD of the $850 i spent back). The cams most definitely appear to be GSR cams, but to be 100% sure, you should get the lobes measured..........</TD></TR></TABLE>
Its a Pr3 casting. it was made in 98. Its not a b17 head or Gsr head. So the cams were added. Im just trying to find out exactly what they are. I just check intake. Its the same.
-Eric
Old May 17, 2004 | 02:35 PM
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">Definately NOT ITR's. They are either B17's or GSR's. My GSR's looked like those, but I've seen some B17's look like those too.</TD></TR></TABLE>
I hope there Like a newer Gsr cam. Id hate to have a cam designed for 1.7L engine in a 1.8, Just plain stupid. If there GSR then they will be good for turbo when i go NA in 2 yrs.
But i bought the car and it was supposed to have ITR cams. Im very angry.
-Eric
Old May 17, 2004 | 03:52 PM
anyone got any other input?
Old May 17, 2004 | 04:06 PM
skunked's Avatar
GSR cams buddy.
Old May 17, 2004 | 06:04 PM
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">GSR cams buddy. </TD></TR></TABLE>
okay we figured that out.
B17, B18c1. what year etc etc.
-Eric
Old May 23, 2004 | 10:26 AM
93gen2's Avatar
It could very well be a b16 head and b16 cams.
Old May 23, 2004 | 11:26 AM
milton's Avatar
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (93gen2)
where'd you get them?
Old May 23, 2004 | 11:39 AM
G
sh!t happens.
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (milton)
bump... waht is the difference between the b17 cam and the b16 cam
Old May 23, 2004 | 11:48 AM
BACKintheDA's Avatar
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (G"UNIT)
This might help..
Old May 23, 2004 | 12:24 PM
Slow_Em1's Avatar
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (DAsmurf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAsmurf &raquo;</TD></TR><TR><TD CLASS="quote">This might help.. </TD></TR></TABLE>
i cant tell just by looking that its none of those.
Old May 23, 2004 | 12:34 PM
G
sh!t happens.
are the b17and b16 cams the same?
Old May 23, 2004 | 12:48 PM
jDMJeRk's Avatar
1st gen b16 cams look different then gsr cams. Here is my really big pic because im lazy but these are gsr cams. i have 1st gen b16 cams and there are no grooves on any parts on the ends of them. Im pretty sure those arent b16 and they arent gsr unless they are newer then the ones i have now. these are a 94 gsr
Old May 23, 2004 | 01:34 PM
G
sh!t happens.
Default Re: What cams are these, ITR, GSR, B17, CTR etc. etc. (jdmjerk)
i see
Old May 23, 2004 | 01:42 PM
B17 and GSR cams have the same lift and duration. Same thing esentially
-Eric
Old Jul 2, 2004 | 02:31 PM
bpowa's Avatar
interesting
Old Jul 2, 2004 | 08:16 PM
JDM-TypeRteg's Avatar
Its hard to tell with those pictures.... they look like b17 but then again ITR did you buy these cams and sre not sure if they are what the seller said they are... or what hope there what there supposed to be... if not
95lsturbo
Aug 8, 2011 02:57 PM
staindgd
Jan 28, 2008 06:28 PM
guymosiris
Sep 3, 2003 06:09 PM
gsrteg
Feb 6, 2003 11:29 AM
12 oz.
Jun 20, 2002 06:19 PM
