Cams for b18b
Old May 17, 2004 | 01:10 PM
CivicHatchback14's Avatar
Default Cams for b18b
hey, what are some cheap cams that will provide some noticeable gains for a N/A b18b, with a b16 tranny? I may do some cams sometime soon.
Old May 17, 2004 | 03:13 PM
Ekasey's Avatar
Default Re: Cams for b18b (CivicHatchback14)
JG old school like 4 years ago showed 10 hp at peak rpm on one motor we had
motor had 178,000 miles and gained 10 hp at peak rpm with itnake and exhuast
Modified by eLusive ek4 at 12:36 AM 5/18/2004
Old May 17, 2004 | 03:16 PM
non-VTEC's Avatar
crower makes great cams that have been proven time and time again to make good power on the B18B engine
you may want to look into crower 403's for the street. 404's for more track only use.
Old May 17, 2004 | 03:18 PM
Tuned1's Avatar
Every LS we Dyno gains 10-15 wheels HP from Crowers' 403's
Old May 17, 2004 | 05:36 PM
Default Re: (Tuned1)
thanks guys
Old May 17, 2004 | 07:23 PM
1point5CRX's Avatar
Default Re: (CivicHatchback14)
what about turbo ls cams ?
Old May 17, 2004 | 08:17 PM
StyleTEG's Avatar
Default Re: (1point5CRX)
The 404s are beyond streetable. Don't bother with the 403's.
Old May 17, 2004 | 10:03 PM
civickiller's Avatar
Default Re: (StyleTEG)
why dont bother with the 403s ?
Old May 18, 2004 | 06:03 AM
Shagrath's Avatar
Default Re: (civickiller)
Spoon, comptech, Skunk2.
not so cheap but good quality ! (like everyone know I geus )
BTW: sorry for my bad English, I'm from Belgium...
Greetz !
Old May 18, 2004 | 07:45 AM
Ekasey's Avatar
Default Re: (Shagrath)
ummm those are VORTECH cams duh? anyways those same jg's pciked up 10 all mota and then 27 boosted
7psi with a drag gen 2 kit +27 hp after cam isntall
Old May 18, 2004 | 08:31 AM
StyleTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">why dont bother with the 403s ?</TD></TR></TABLE>
Because people go with the 403's because they HEAR that the 404s are lopey or idle like crap.
Those who say they are lopey or idle like crap have never installed them, or never ridden in a car with them, because my car idles like stock inside the car.
Motor mount inserts made a bigger difference in idle quality than the 404s.
Old May 18, 2004 | 12:22 PM
maybe i misunderstood what your saying. your sugesting to use the 404s because they are streetable and not to even consider the 403, is that right ?
Old May 18, 2004 | 12:28 PM
StyleTEG's Avatar
Yeah, I don't see why you would go with 403's if the 404s are just as streetable and make plenty more power?
Old May 18, 2004 | 04:17 PM
anyone know how much the average ls would make with 404s ?
Old May 18, 2004 | 04:23 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">anyone know how much the average ls would make with 404s ?</TD></TR></TABLE>
on a stock bottom end LS and 404's with minor bolt on's and minor tuning you could probably see 150whp or more.
Old May 18, 2004 | 05:10 PM
StyleTEG's Avatar
Default Re: (non-VTEC)
I made 165 with a stock bottom end and 404s.
Old May 18, 2004 | 05:52 PM
Arsenal's Avatar
403=Stock retainers/springs
404=Upgraded Retainers/springs
True or not?
Old May 18, 2004 | 06:16 PM
Default Re: (Arsenal)
i got another questions, what are the biggests cams you can run that will still be streetable, any company ?
Old May 18, 2004 | 06:56 PM
StyleTEG's Avatar
no, with the 403s you need upgraded springs
Old May 24, 2004 | 05:47 AM
smallttocs's Avatar
are the 403s or 404s good for a turbo'ed b18b?
Old May 24, 2004 | 06:52 AM
non-VTEC's Avatar
Default Re: (smallttocs)
crower has some nice turbo cams for the LS engine. grind number 62402T
high lift and low duration which make it awesome for turbo.
although i have hear of someone using 403's properly tuned with turbo and making good power.
Old May 24, 2004 | 11:21 AM
Lscivichatch92's Avatar
how does a b16 tranny feel with a b18. do the gears feel that much shorter and what is ur rpm at on the highway.
not to thread jack, but the only reason i ask is, i need better gearing than an ls motor and b16s have the shortest for drag like i want.
Old May 24, 2004 | 11:23 AM
non-VTEC's Avatar
Default Re: (Lscivichatch92)
the B16 tranny will give you the greatest acceleration. and for drag racing thats what you want. on the freeway you will be buzzing over 3500rpm or more at around 60mph.
personally i run a GSR tranny and i love it.
Old May 24, 2004 | 04:03 PM
Arsenal's Avatar
What sort of times did you change between the GSR and the LS tranny?
Ice-Nine
Aug 18, 2009 12:00 PM
96tegls2dr
Jul 13, 2006 03:30 PM
fuguman
Jul 24, 2002 08:40 AM
