water pump trouble ...
ok .. i want to change this water pump right ... there are 4 bolts to install the water pump .. i took 3 bolts out and the last bolt stripped .. and now theres a thread in it .... how can i take it out .. without damaging the engine .... ? any suggestions .. please reply back .. because of that bolt .. i cant get my car to run because of that bolt cuz the coolant gonna leak ...
go to sears and buy the sockets that remove bolts that have stripped heads. They run about 20 or 30 bucks for a set. You'll need the 8mm-14mm set I believe since the bolt you f'd up is a 10mm.
i need a small drill .. to drill it out .. is there any small drill out there ?? cause the water pump have very lil room to work on ... ne plans?
