Checking codes: obd2 car with obd1 conversion.
Old May 17, 2004 | 11:03 AM
stevieteg's Avatar
Default Checking codes: obd2 car with obd1 conversion.
I have a b18c1 in my ls integra, it runs fine, but I'm throwing a code. Car is obd2 and I'm using a jumper harness and using a obd1 p72 ecu. How do you check the codes on an obd2 car with an obd1 conversion?
Old May 17, 2004 | 11:11 AM
98HB's Avatar
Default Re: Checking codes: obd2 car with obd1 conversion. (stevieteg)
http://www.c-speedracing.com/faq/05.php
Old May 17, 2004 | 11:14 AM
Reason's Avatar
It should be a l blue plug over by the ecu, use a piece of wire and jump it. then watch the check engine light flash for your code.
Old May 17, 2004 | 11:35 AM
H25's Avatar
H25
the same way you check it on a obd1 car.
EkCoupeTurbo
May 13, 2013 05:16 PM
BLUE EH3
May 13, 2005 08:19 PM
anduknodis
Sep 18, 2004 11:54 AM
EKHappy
Nov 13, 2002 05:09 PM
43MA
Oct 29, 2002 11:35 PM
