are non abs axles smaller than abs axles on a b series
Old May 17, 2004 | 09:20 AM
slosol's Avatar
Default are non abs axles smaller than abs axles on a b series
is there a difference
Old May 17, 2004 | 09:24 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: are non abs axles smaller than abs axles on a b series (slosol)
No, they are the same. But the ABS axles have that metal toothed ring around the outer boot. That's all.
Old May 17, 2004 | 11:40 AM
slosol's Avatar
Default Re: are non abs axles smaller than abs axles on a b series (shamoo)
thanks bro
Old May 17, 2004 | 12:05 PM
ThePro's Avatar
Can you stick abs axles on a non-abs car or vice versa?
Old May 17, 2004 | 12:11 PM
PM-Performance's Avatar
Default Re: (ThePro)
yes, but if you put non abs axles on an ABS car you wont have working abs.
Old May 17, 2004 | 12:15 PM
Chris's Avatar
Default Re: (itr206)
I also think your ABS light will come on.
(duh) heh
Old May 26, 2004 | 06:22 PM
weraider30's Avatar
Default Re: (Chris)
this is kinda off subject, but what is the difference b/w non abs rotors and abs....
Old May 26, 2004 | 07:03 PM
shamoo's Avatar
Default Re: (weraider30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weraider30 &raquo;</TD></TR><TR><TD CLASS="quote">this is kinda off subject, but what is the difference b/w non abs rotors and abs....</TD></TR></TABLE>
Nothing.
The only MAIN difference between stock rotors is whether they are vented or not. Usually on our cars, stock front rotors are vented, and rears are not.
ABS rotors and non-ABS rotors are the same.
Old May 26, 2004 | 07:06 PM
weraider30's Avatar
Default Re: (shamoo)
so i could put some drilled/slotted rotors made for abs on my eg hatch dx?
Old May 26, 2004 | 07:26 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weraider30 &raquo;</TD></TR><TR><TD CLASS="quote">so i could put some drilled/slotted rotors made for abs on my eg hatch dx?</TD></TR></TABLE>
Yes, as long as they are the right size. And as long they are vented in the front, you'll be fine.
Old May 26, 2004 | 07:50 PM
weraider30's Avatar
do you know the largest size i can fit on 97 ITR calipers
bob441
Nov 11, 2015 06:50 PM
204hatch
Apr 4, 2008 09:11 AM
shortycm17
Dec 26, 2007 03:31 PM
arsenaldragster
Apr 24, 2005 10:49 PM
charjacq
Mar 2, 2003 09:21 AM
