Can i drive a tuned map for 550cc with 700-750cc injectors??
Old May 17, 2004 | 08:34 AM
Weedm4n's Avatar
Default Can i drive a tuned map for 550cc with 700-750cc injectors??
Hello
My car is tuned for rc 550 cc injectors can i drive the same hondata map wtih the upgraded Rc 750cc injectors?? What is possible to do
Old May 17, 2004 | 08:42 AM
H22isnotabigblock's Avatar
Default Re: Can i drive a tuned map for 550cc with 700-750cc injectors?? (Weedm4n)
you might be able to but i can almost guarantee it will run rich, which might wash down the cylinder walls, be careful...
*eric*
Old May 17, 2004 | 09:00 AM
Rtype16's Avatar
Default Re: Can i drive a tuned map for 550cc with 700-750cc injectors?? (H22isnotabigblock)
It will run rich they might have a function in the ECU to change the fuel map using a calculation of old injectors to new injectors. Also the other thing you want to make sure of. The old injectors and the new injectors are they high impedence or low. They may not be the same.
Old May 17, 2004 | 09:07 AM
Weedm4n's Avatar
Default Re: Can i drive a tuned map for 550cc with 700-750cc injectors?? (Rtype16)
But another question . if i want to drive 400-450 hp onmy setup can i do it with 580 saturadet??? How much duty cycle is there?
Old May 17, 2004 | 09:09 AM
TurboB18C1's Avatar
could you post you setup
Old May 17, 2004 | 09:13 AM
Weedm4n's Avatar
Default Re: Can i drive a tuned map for 550cc with 700-750cc injectors?? (TurboB18C1)
B16A2 with Ge Sleeves 81,5mm bored.
Srp Pistons 81,5mm and a ratio of 8;5,1
GarrettT3/T04E 63.ar turbine 57trim and 50Ar compressor
Lovefab SST
Lovefab 3" Downpipe
KMS Nitrided valves
Crane cams retainers and springs
Ge rodīs
complete 3" exhaust
38mm Tail Wastegate
3 bar mapsensor
Starion IC
2,5" Ic pipe
Old May 17, 2004 | 10:19 AM
Rtype16's Avatar
This is with your 550's
At 40 psi of fuel pressure and a BSFC of .6. 100% duty will get you 334.5 hp.
However with a BFSC of .6 100% duty at 120psi of fuel pressure you can make 580hp. lol.
Your 750
At 40 psi of fuel pressure and a BSFC of .6. 80% duty will get you 365 hp.
At 40 psi of fuel pressure and a BSFC of .6. 100% duty will get you 456 hp.
However with a BFSC of .6 100% duty at 101psi of fuel pressure you can make 580hp. lol.
Modified by Rtype16 at 11:34 AM 5/17/2004
the_insider
Sep 5, 2015 01:01 PM
chagus
Apr 10, 2013 10:09 PM
DJaeMac
Sep 28, 2007 03:06 PM
teg racer 877
Feb 11, 2006 09:10 AM
Vadian
Jul 30, 2003 05:31 PM
