fuel leak after fuel pump install
Old May 17, 2004 | 06:34 AM
red civic standard's Avatar
Default fuel leak after fuel pump install
I just installed a Walbro fuel pump in my 91 civic (pain in the ***). Car started fine with no leaks. Then I went to the gas station to fill up. Put in a full tank and noticed major leakage from what seems to be the top part of the tank. After using a couple gallons of gas driving, the leakage problem seems to have subsided.
Is it possible that there is a leak where the filler neck goes into the tank? Are you supposed to disconnect the filler neck at the gas cap when you drop the tank?
Old May 17, 2004 | 10:54 AM
Default Re: fuel leak after fuel pump install (red civic standard)
up
biff206
Dec 12, 2013 04:08 AM
91cb7h23
Feb 10, 2013 04:13 PM
uberEFtuner
May 23, 2010 10:59 AM
kaoss_11
11
Dec 9, 2004 08:29 PM
Malgerus
17
Jun 14, 2003 08:08 PM
