help. timmings off
Old May 17, 2004 | 01:47 AM
ghosts's Avatar
New User
Default help. timmings off
will, i just recently put on some type r camshafts and when i do my timming with the motor turned off, everything lines up. but when i use the timming gun to check my timmning, it's off. and i would have to retard the disturbutor all the way for it to line up... do u guys know whats worng?????? help!!!!!!!!
Old May 17, 2004 | 03:16 AM
ghosts's Avatar
New User
help anybody????????
Old May 17, 2004 | 06:23 AM
JimBlake's Avatar
Default Re: (ghosts)
Which timing are you talking about? You check camshaft timing with the engine turned off, by lining up marks on crankshaft & camshaft pulleys. No timing light here, & this has nothing to do with turning the distributor. You say everything lines up, so it sounds like this is OK.
You check spark timing by using a timing light... You can't really do this with the engine turned off. Does your timing light have an advance dial? Set it to ZERO & look for the middle of 3 closely-spaced marks on the crank pulley.
b20integrapower
Apr 9, 2006 05:32 PM
kholmes
May 24, 2004 07:01 AM
91crx but i heard vtec
Nov 18, 2003 04:18 PM
90teg
Aug 26, 2003 01:45 AM
wantmorepower
Apr 16, 2003 09:52 PM
