black smoke coming out of exhaust
Old May 16, 2004 | 10:31 PM
xplanetearth420x's Avatar
Default black smoke coming out of exhaust
well my friends was driving behind me the other day and he told me that my car had smoke coming out of the exhaust
first thing i did was change the oil but i want to know if anyone knows what could me wrong and why black smoke would be coming out
before i spend money on things u dont need to do
thanks for your help
Old May 17, 2004 | 01:24 AM
Toda Built's Avatar
Default Re: black smoke coming out of exhaust (xplanetearth420x)
It could be a couple of things... what mods do you have on your car?
1. your car could just be running rich (which most honda's do as a safety precaution)
2. Pistons rings could be going bad and your getting oil blow by
3. a bunch of other things that i'm sure other people will fill in after me
Old May 17, 2004 | 05:22 AM
IntegraLs94Cam's Avatar
Default Re: black smoke coming out of exhaust (Toda Built)
most likely it is carbon build up.... everyone's exhaust has carbon build up in it .... and when u floor it some of it gets blowed out don;t worry when i first got my car someone told me black smoke was comeing out my car and i got all worryed. but i soon found out it was just carbon in the exhuast .... if u look at ur exhuast u can put ur finger tip in there and there will be alot of black on ur finger.. that is the carbon build up.
Old May 17, 2004 | 08:11 AM
blackcruzan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Built &raquo;</TD></TR><TR><TD CLASS="quote">It could be a couple of things... what mods do you have on your car?
3. a bunch of other things that i'm sure other people will fill in after me</TD></TR></TABLE>
i thought number 2 on your list is white smoke
Old May 17, 2004 | 08:50 AM
GeorgieC419's Avatar
Default Re: black smoke coming out of exhaust (blackcruzan)
Yea, I guess I have a similar question. But I'm experiencing blue smoke. Just a little bit, in first gear, when the car is warm. Any help is appreciated. Thanks
PS- this is in my 90 AWD Civ
Old May 17, 2004 | 09:26 AM
Default Re: black smoke coming out of exhaust (GeorgieC419)
i have header and intake
i do see some carbon build up but not too much gets on the back of my bumper so i dont know
what can i do to fix it
Old May 17, 2004 | 09:33 AM
spark plugs.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcruzan &raquo;</TD></TR><TR><TD CLASS="quote">
i thought number 2 on your list is white smoke</TD></TR></TABLE>
no, number 2 on the list is blue smoke. white smoke is anti-freeze/coolant burning.
Old May 17, 2004 | 09:34 AM
furious94ls's Avatar
Lets go back to basics.
White smoke: Coolant/water usually the sign of a blown head gasket. When its really cold our or when running and not warmed up its just moisture and condesation.
Blue Smoke: Buring oil, Valve seals, piston rings
Black smoke: Fuel, running rich, Get your car tuned.
Old May 17, 2004 | 10:03 AM
Default Re: black smoke coming out of exhaust (furious94ls)
so i should just try reseting my ecu
Old May 17, 2004 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeorgieC419 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, I guess I have a similar question. But I'm experiencing blue smoke. Just a little bit, in first gear, when the car is warm. Any help is appreciated. Thanks
PS- this is in my 90 AWD Civ</TD></TR></TABLE>dont try to take over a threads noob
Old May 17, 2004 | 12:32 PM
ttt
Old May 17, 2004 | 12:54 PM
spark plugs.
Guest
Posts: n/a
are you throwing a CEL? does the driveability of the car feel any different? how does the exhaust smell, if you're not burning rich for some reason, then it's probably just carbon build up. resetting your ecu won't do much. give us detailed symptoms. is it while you're driving? idling? WOT?
Old May 17, 2004 | 01:43 PM
Default Re: black smoke coming out of exhaust (troublecodes)
while diving over 4k rpms
smell like ****
black smoke
check engine isnt on
if its carbon build up is there anything i can do?
Old May 17, 2004 | 02:00 PM
eric8876's Avatar
Since u do have intake header, you have a good chance hat ure running rich r u gettin shitty mileage like 15 or somethin???
Old May 17, 2004 | 02:13 PM
Quiks66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">dont try to take over a threads noob
I'm finding it a little funny that you're saying this...your User Info says you're 16 years old...and though you've been a member for a while, i've noticed that most of your posts are responses like "ya", "turbo it", and "sweet". Ya.
But in response to the Q, your motor is most likely running rich. Get a fuel pressure regulator, gauge, and VAFC and get it tuned.
Old May 17, 2004 | 03:14 PM
Default Re: black smoke coming out of exhaust (Quiks66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quiks66 &raquo;</TD></TR><TR><TD CLASS="quote">
But in response to the Q, your motor is most likely running rich. Get a fuel pressure regulator, gauge, and VAFC and get it tuned.</TD></TR></TABLE>
regaurding the top part
ive dont say sweet first off and i dont see why i would say ya unless it was asking a question
back to the problem i have noticed im getting shitty gas milage
dont see a reason to drop all that money on a vafc when hardly anything is done to my car i will need to get it tuned though
Old May 17, 2004 | 03:16 PM
cougar10ag's Avatar
Blue smoke=oil
white smoke (not to be confused with normal exhaust vapor)=coolant
black smoke=carbon
Old May 17, 2004 | 03:24 PM
Default Re: (cougar10ag)
is there something i can do to stop the carbon build up?
Old May 17, 2004 | 03:39 PM
slo2kgsr's Avatar
Default Re: (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">is there something i can do to stop the carbon build up?
No carbon is a by product of all combustion engines. They have prducts to clean out your vacume system but, not exhaust.
Old May 17, 2004 | 04:53 PM
Default Re: (tegraLS97)
anything else?
Old May 17, 2004 | 04:54 PM
cougar10ag's Avatar
yup.. tear down and clean your cyl head and pistons every week.
Old May 17, 2004 | 05:03 PM
Sliced Beard's Avatar
if you are getting really bad gas mileage your O2 sensor may be going bad and it has yet to throw a code. It happened to me and after i replaced it my car ran better and it burnt less gas. The only catch is that O2 sensors cost a good bit
Old May 17, 2004 | 07:18 PM
Default Re: (dirtyd463)
im gonna try some carbon clean in the next few days we'll see how that goes
Old May 17, 2004 | 09:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes &raquo;</TD></TR><TR><TD CLASS="quote">
no, number 2 on the list is blue smoke. white smoke is anti-freeze/coolant burning.</TD></TR></TABLE>
thanks
Old May 18, 2004 | 02:24 AM
IntEGNYC's Avatar
We get white smoke when we're apply sea-foam...
are you sure the white isnt carbon?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cougar10ag &raquo;</TD></TR><TR><TD CLASS="quote">Blue smoke=oil
black smoke=carbon</TD></TR></TABLE>
