Redline 6000 rpm in a gsr?? fried ecu?
Old May 16, 2004 | 09:12 PM
JdmIntegra98's Avatar
Default Redline 6000 rpm in a gsr?? fried ecu?
my car is redling at 6000 just recently after recieving a atomsphere pressure cel... i dont boost car is mostly stock... i reset the ecu serveral times and i still cant rev past around 6 -7000.... i dont know what is wrong.. it seems like the car is just slamming around at that rpm not really cut off just feels really werid.. any ideas?? ecu?
Old May 16, 2004 | 10:16 PM
Turn or Burn's Avatar
Default Re: Redline 6000 rpm in a gsr?? fried ecu? (JdmIntegra98)
Too vague
Old May 16, 2004 | 11:09 PM
Dont post if you dont wanna help.. ask me questions if you need info...
Old May 16, 2004 | 11:32 PM
eyeamvic's Avatar
Still throwing a check engine light?
Old May 17, 2004 | 12:45 AM
JDMorgan's Avatar
i heard people only abled to rev to 6 when vtec wasnt workin.
Old May 17, 2004 | 08:44 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: (KraZEtEggIE)
do you still get the CEL? if it's still on then the car will still be in limp mode. are you resetting via the fuse or the battery?
Old May 17, 2004 | 10:31 AM
i am resetting the battery... what fuse should i use.. and what is the difference.. the light went away.. after the first reset
Old May 17, 2004 | 10:47 AM
wickedEFguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">i heard people only abled to rev to 6 when vtec wasnt workin.</TD></TR></TABLE>
you are correct
You will be reving out that high since the ECU is running in Limp mode and the revlimiter of the primary lobe is around 6-7K
What CEL and ECU are you using
Old May 17, 2004 | 11:31 AM
i figured it out.. when i shake the wires in the back of my map sensor the car dies.. if i am reved up the car bounces around.. so it must be the car bouncing around there that pulls on the wires?? bad map sensor or the wires loose? or could it be a peice of the gasket blocking air flow to it?
Old May 17, 2004 | 11:32 AM
Default Re: (JdmIntegra98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmIntegra98 &raquo;</TD></TR><TR><TD CLASS="quote">i figured it out.. when i shake the wires in the back of my map sensor the car dies.. if i am reved up the car bounces around.. so it must be the car bouncing around there that pulls on the wires?? bad map sensor or the wires loose? or could it be a peice of the gasket blocking air flow to it?</TD></TR></TABLE>
get out a voltmeter and check for any shorts you might have
Old May 17, 2004 | 03:39 PM
fixed it.. got the new connection.. and it works great.. thanks for listening..
CRVTECSCREAMER
Mar 17, 2010 10:30 PM
sivikvtec
Aug 18, 2008 06:12 PM
ultimatehonda
Honda Civic (2006 - 2015)
Jun 12, 2007 04:08 PM
b0yg0tskills
Honda Civic (2001 - 2005)
11
Nov 26, 2006 07:18 PM
burgboy73
Nov 6, 2006 06:06 AM
