00-01gsr header on 95 gsr......... how do i make it fit?
Well i accidentally purchased a header that is supposedly only for the 00-01 gsr and i have a 95. I was wondering exactly what is different.
I also have a friend that is selling an exhaust system from an ls. Now if i used the 00-01 header and ls exhaust, i should have no fitment problems right? Any input would be sweet.........
-Jared
-Jared
you might have to do some welding b/c the header mounts in a diff spot under the 95 - but the header and ls pipes match so the answer is yes with some slight modification - if your already welding though you could shorten the b-pipe(cat) and keep your exaust if you want - theres an article on team-integra about the diffs
If your friend is also offering the LS cat along with the exhaust, then everything will bolt directly on to your car with no modifications.
If your friend is also offering the LS cat along with the exhaust, then everything will bolt directly on to your car with no modifications. If not, you'll need either an LS or '00-'01 GS-R cat to use with the LS cat-back in order for everything to bolt up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">If your friend is also offering the LS cat along with the exhaust, then everything will bolt directly on to your car with no modifications. If not, you'll need either an LS or '00-'01 GS-R cat to use with the LS cat-back in order for everything to bolt up. </TD></TR></TABLE>
excellent.......... thanx alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frenchy »</TD></TR><TR><TD CLASS="quote">i was close</TD></TR></TABLE>
19integra94
Apr 16, 2009 08:24 AM
phateless
Jan 3, 2006 06:49 PM
