OBD1 b18a swap help
Old May 16, 2004 | 06:40 PM
integraracing91's Avatar
Default OBD1 b18a swap help
When wiring in the OBD1 injectors, can i just unplug the resistor and be done with it?
Thanks,
Brendan
Old May 17, 2004 | 06:29 AM
Default Re: OBD1 b18a swap help (integraracing91)
Bump
Old May 17, 2004 | 11:24 AM
saleensolution's Avatar
ive seen people cut all the wires going to the box and then tape them all together and it works ok
Old May 17, 2004 | 12:05 PM
Colin's Avatar
remove the resistor box
clip all the wires, strip the ends
connect all the wires together, preferrably w/ the oem style connector used on obd1 cars, or soldered together. Simply taping them together should work, but its pretty ghetto
Basically all you're doing is grounding the injectors.
Old May 18, 2004 | 04:52 AM
1st-hybrid's Avatar
Default Re: OBD1 b18a swap help (91IntegGS)
Correct either one of these will work.
On my first swap I went the ghetto route, ie.. electrical tape. This time around I'm using the obd1 connector.
hedtrip
Apr 28, 2006 08:00 PM
Fusion G2 Civic
14
Dec 22, 2005 09:49 AM
shauniewalnuts
Nov 22, 2004 07:15 PM
civicefdx
Oct 24, 2004 03:25 PM
