erratic idle when warm
i did my b16 swap in my 89 hatch and it idles fine when cold but when it gets to operating temperature then i get a fluctuating idle, help? thanks a lot
wow i just researched it and then it sounds like my problem, when i get home i am going to give that a try, thanks a lot, honda tech pwnz all
if you need more help than that let me know i just fixed that problem on my friends car. The pictures under 123 fitv or whatever dont work no more but i can walk you through it if you need help
DEF
DEF
yeah his fitv had fallen out because it became unscrewed...its underneath the throttle body on his car. his name is hondaguyef if you want to talk to either of us. But he just had a kid last night so he is at hospital with his wife. Also im not sure why it becomes unscrewed over time but it does so check that out...maybe yours hasnt fallen alway out and probably needs to just be tightened back in.
DEF
DEF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efvader »</TD></TR><TR><TD CLASS="quote">My civ does the same thing too it idles up high and goes up and down only when warm. hmmm I wonder if I should check my tb gasket as well.</TD></TR></TABLE>
I would.. but get a new one b4 u remove the TB cuz i wouldnt reuse it.
FlatlineEF9
Aug 26, 2004 07:06 PM
