Will running larger wheels in the rear slow acceleration
Old May 16, 2004 | 04:17 PM
NiceDc2r's Avatar
Default Will running larger wheels in the rear slow acceleration
I plan on running a 15x7 wheel on the front w/ 205 50 15 Drag radial in the front and a 16x7 205 45 16 in the rear...will this hurt or help my 1/4 mile imes
Old May 16, 2004 | 04:40 PM
BlownVR's Avatar
Default Re: Will running larger wheels in the rear slow acceleration (NiceDc2r)
it will hurt, why can you just get 15's for the rear also???
Old May 16, 2004 | 04:41 PM
BlownVR's Avatar
Default Re: Will running larger wheels in the rear slow acceleration (H22BuiltEGhatch)
but it won't hurt it tooo bad because there only 16's but i ouls still go with the 15's. you might see 1/10th off if you go with the 15's in the rear also..just my 2 cents
Old May 19, 2004 | 02:28 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22BuiltEGhatch &raquo;</TD></TR><TR><TD CLASS="quote">but it won't hurt it tooo bad because there only 16's but i ouls still go with the 15's. you might see 1/10th off if you go with the 15's in the rear also..just my 2 cents</TD></TR></TABLE>
doubt it. that has nothing to do with your times, unless they weigh about 50 lbs a piece. just make sure the tire pressure in the rear is higher then normal.
Old May 19, 2004 | 05:19 AM
ceas's Avatar
And where again are you pulling these numbers from?
Old May 19, 2004 | 07:14 PM
DXDOHCVTEC's Avatar
The only difference the back wheel size would make is the weight (because the less total weight the faster) and tire rolling resistance (like slow em1 said)
Old May 20, 2004 | 05:40 PM
jeremy.'s Avatar
Default Re: (DXDOHCVTEC)
hey josh think when i get back from westpac you'll be able to respond to pm's!!!???
T3k C
Jun 29, 2006 04:16 PM
eg6sir-s
17
Feb 19, 2006 05:08 PM
Mr. Lucky
Honda S2000
18
May 31, 2005 06:09 PM
Mr. Lucky
Honda S2000
13
May 3, 2005 11:11 PM
bdicustoms
17
Feb 19, 2004 06:19 PM
