clutch/flywheel
Old May 16, 2004 | 12:52 PM
honcrx91si's Avatar
Default clutch/flywheel
i think i am going to go with a act clutch and fidanza flywheel... some of my friends say fadanza isn't that good but some say they are.. and also how are exedy clutches? please give me your opinions
Old May 16, 2004 | 01:04 PM
deftones0817's Avatar
Default Re: clutch/flywheel (honcrx91si)
exedy flywheels are chromoly steel
fidanza flywheels are aluminium
usually aluminium is more likely to warp than chromoly if my understand is correct?
it also matters on what exedy clutch you go with some are like stock replacement while so are stronger than stock by a bit.
how much you trying to spend on the combo?
DEF
Old May 16, 2004 | 01:48 PM
RCautoworks's Avatar
Default Re: clutch/flywheel (deftones0817)
You will be happy with fidanza, and if you ever need to resurface it you can just by the replacement friction disc. About it warping, don't worry about it, it will not happen.
Old May 16, 2004 | 02:35 PM
snapcase318's Avatar
I've heard that aluminum flywheels can warp too but I've never heard of anyone having problems with them. On my last car I went with an act clutch and lightened act flywheel and was very hapy with the setup.
Old May 16, 2004 | 02:37 PM
Default Re: clutch/flywheel (snapcase318)
let me repeat i didnt mean it would warp i just heard it could. I have never personally seen one warp...ive never seen a ctr crank pulley mess up an engine but everyone says it could too.
Old May 16, 2004 | 02:53 PM
Rywire's Avatar
I have the fidanza fw, and the act clutch. Great combo. Mines not warped. Ryan
Old May 16, 2004 | 03:15 PM
y49crxsi's Avatar
Default Re: clutch/flywheel (droppedcrxsi)
Had the 8lb fidanza, and a clutchmasters stage 1, loved em, wish i still had them...
Old May 17, 2004 | 04:50 PM
honcrx91si's Avatar
Default Re: clutch/flywheel (y49crxsi)
I want to spend about $450-$500 on the whole thing.... i want to get a good clutch..i'm just alittle hesitant on what i want.. i wanna go alittle better than stock but not alittle where it will get annoying.. cause of having cable clutch they aren't the friendiest combo(cable clutch and high stages on clutch).. but yea that around what i want to spend
Old May 17, 2004 | 04:58 PM
crx_88_si's Avatar
considered shaving the oem flywheel and getting a slightly stronger street clutch?
Old May 17, 2004 | 05:01 PM
Rywire's Avatar
Default Re: clutch/flywheel (crx_88_si)
Thats do-able, get a flywheel and clutch on ebay. Act, and fidanza or similar. Ryan
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Mar 2, 2015 05:02 PM
Heinz57
12
May 26, 2003 04:34 AM
Solipsist
Dec 6, 2002 11:49 AM
