alternator?
Old May 16, 2004 | 12:49 PM
honcrx91si's Avatar
Default alternator?
battery light came on and i've been drivin it for alittle and nothin happened yet but it smells like something is getting hot... please let me know what u think
Old May 16, 2004 | 01:43 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: alternator? (honcrx91si)
Find a voltmeter, you're probably not getting enough charge, alternator probably going bad... or battery is too old and won't hold enough charge anymore. Have battery tested, if battery is good, then its probably the alternator.
Check all your wires going to the alternator, ground wires, etc.
Old May 16, 2004 | 01:46 PM
RCautoworks's Avatar
Default Re: alternator? (LSVTEC 91 Civic)
Test it
TESTING
Voltage Test
Make sure the engine is OFF, and turn the headlights on for 15–20 seconds to remove any surface charge from the battery.
Using a DVOM set to volts DC, probe across the battery terminals.
Measure the battery voltage.
Write down the voltage reading and proceed to the next test.
No-Load Test
Connect a tachometer to the engine.
CAUTION
Ensure that the transmission is in Park and the emergency brake is set. Blocking a wheel is optional and an added safety measure.
Turn off all electrical loads (radio, blower motor, wipers, etc.)
Start the engine and increase engine speed to approximately 1500 rpm.
Measure the voltage reading at the battery with the engine holding a steady 1500 rpm. Voltage should have raised at least 0.5 volts, but no more than 2.5 volts.
If the voltage does not go up more than 0.5 volts, the alternator is not charging. If the voltage goes up more than 2.5 volts, the alternator is overcharging.
NOTE: Usually under and overcharging is caused by a defective alternator, or its related parts (regulator), and replacement will fix the problem; however, faulty wiring and other problems can cause the charging system to malfunction. Further testing, which is not covered by this book, will reveal the exact component failure. Many automotive parts stores have alternator bench testers available for use by customers. An alternator bench test is the most definitive way to determine the condition of your alternator.
If the voltage is within specifications, proceed to the next test.
Load Test
With the engine running, turn on the blower motor and the high beams ( or other electrical accessories to place a load on the charging system).
Increase and hold engine speed to 2000 rpm.
Measure the voltage reading at the battery.
The voltage should increase at least 0.5 volts from the voltage test. If the voltage does not meet specifications, the charging system is malfunctioning.
tish_86
Classic Hondas
Jun 3, 2014 08:00 AM
GPC91
Oct 3, 2012 03:46 PM
Byaaah!
Jan 30, 2007 12:06 AM
smash fascism
Dec 22, 2005 09:13 PM
97dc2
Mar 8, 2005 11:31 AM
