oil plug crush washer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">will one from a b16a work?
how much does it cost at dealer too
i got a b18a</TD></TR></TABLE>
Yes it will work, and they're only a few cents at the dealer (some will include the washers if you buy a filter from them).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIK IN DA HED »</TD></TR><TR><TD CLASS="quote">just use one that fits the plug. go to home depot or something if you need to.</TD></TR></TABLE>
The Honda washer is specifically designed to "crush" slightly in order to form a better seal (hence the reason why it is recommended to replace the washer at each oil change). Most, if not all, of the washers one would find somewhere like Home Depot would be much harder, and thus wouldn't deform the way the OEM part does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-tag »</TD></TR><TR><TD CLASS="quote">I got mine for free</TD></TR></TABLE>
wow, now that's an informative post
don't cheap out on a damn washer, go to the dealer and ask them how much or go to http://www.acuraautomotiveparts.org
most honda and acura crush washers are usually interchangable. I would start going to the dealer and if you get really desperate try going to to kwik lube or somthing of the nature.
Mine was 23 cents at the dealer. I only got charged for it once. Every other time I went, they gave it to me free with the filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackThorN »</TD></TR><TR><TD CLASS="quote">it was like 7 cents at autozone</TD></TR></TABLE>
I know this topic is old but I was an aware autozone sold them, in what section did they carry them ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dent Free »</TD></TR><TR><TD CLASS="quote">You can find any Soft Alum. ring aslong as it has a 14mm hole. All Honda Oil plugs are 14mm ( thread size )</TD></TR></TABLE>
Actually Honda's crush washers are made of a special material that is made to be crushed once. I'll ask tomorrow at autozone but I am almost sure the one over here does not have them
Modified by 90blackcrx at 1:07 AM 9/30/2004
JCracer723
21
Feb 8, 2007 04:51 PM
