mini-me compression, whats safe?
Old May 16, 2004 | 11:05 AM
underage's Avatar
Default mini-me compression, whats safe?
this will be daily driven, so i need reliability.
it will be converted to obd1 or obd2, and will be on stock fuel management. here's my two options:
d15b1 bottom end/z6 head/y8 gasket= about 10.42:1 compression
d15b1 bottom end/y8 head/y8 gasket- about 10.86:1 compression
which is safer to run on 90 octane pump gas? if they are both safe, will the y8 head or the z6 head make more power?
Old May 16, 2004 | 11:13 AM
infinatenexus's Avatar
Both compression ratios will work on pump gas just fine.
Old May 16, 2004 | 11:43 AM
y49crxsi's Avatar
Default Re: (infinatenexus)
and the y8 will be a tad stronger, due to the higher compression, but make sure to put 91 or above octane in...
Old May 16, 2004 | 11:44 AM
y49crxsi's Avatar
Default Re: (y49crxsi)
Oh, and swap to obd1, no one swaps to obd2 unless its for emisions, and if thats your case, go with the z6, so you can swap to obd1, alot easier and cheaper. But also, if your worried about emisions, you wouldnt be doing a minime, so yeah, y8 with obd1...
Old May 16, 2004 | 11:50 AM
ham's Avatar
ham
Default Re: mini-me compression, whats safe? (underage)
is y8 also sohc vtec?
Old May 16, 2004 | 11:58 AM
EG8R's Avatar
Default Re: mini-me compression, whats safe? (zcnos)
Yes it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcnos &raquo;</TD></TR><TR><TD CLASS="quote">is y8 also sohc vtec?</TD></TR></TABLE>
Old May 16, 2004 | 12:09 PM
ham's Avatar
ham
Default Re: mini-me compression, whats safe? (skelly ed666)
then with the y8 it will run 10s! youll have to run 116 octane though.
Old May 17, 2004 | 02:17 PM
underage's Avatar
is there any other way to tweak a little more compression out of the z6 head without touching the pistons or having anything milled?
Old May 17, 2004 | 02:19 PM
underage's Avatar
how would i convert the y8 to obd1? would i get a obd2&gt;obd1 adapter and a obd0&gt;obd1 adapter?
Old May 17, 2004 | 07:12 PM
underage's Avatar
bump
Old May 18, 2004 | 05:04 PM
underage's Avatar
can i use the z6 ecu with the y8 head?
Old May 18, 2004 | 05:57 PM
Default Re: (underage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underage &raquo;</TD></TR><TR><TD CLASS="quote">can i use the z6 ecu with the y8 head?</TD></TR></TABLE>
yes
Old May 18, 2004 | 08:16 PM
d357r0y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underage &raquo;</TD></TR><TR><TD CLASS="quote">is there any other way to tweak a little more compression out of the z6 head without touching the pistons or having anything milled?</TD></TR></TABLE>
take out the middle layer in the OEM gasket.
Old May 19, 2004 | 05:00 PM
underage's Avatar
Default Re: (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">
take out the middle layer in the OEM gasket. </TD></TR></TABLE>
does this apply to the y8 head gasket, because i thought that the y8 head gasket was 2-layer?
Joey Mitchell
Nov 19, 2018 11:53 AM
zcrx2006
Nov 29, 2007 07:25 PM
Mr_Moos
Mar 19, 2005 08:15 PM
99hatch
Feb 1, 2005 08:36 AM
ej8
Apr 17, 2003 06:34 AM
