lug nut wont come off. pls. help ASAP
Old May 16, 2004 | 09:36 AM
JDMluvR's Avatar
Default lug nut wont come off. pls. help ASAP
Hey, what's up everyone? Well, my brother has a 90 hatch and he was trying to take change his tires until one of the lug nuts just kept spinning. now it is really loose and it will not tighten back up either, so right now it is just sitting on there really loose but its not going anywhere. Anyone have this problem before? Thanks for any help.
Old May 16, 2004 | 09:53 AM
Jonathan_ED3's Avatar
Default Re: lug nut wont come off. pls. help ASAP (JDMluvR)
So the actual stud (lug) is just spinning with the lug nut?
Old May 16, 2004 | 10:19 AM
JDMluvR's Avatar
Default Re: lug nut wont come off. pls. help ASAP (Jonathan_EH)
Yes, but it wont pop out, I find that kinda strange.
Old May 16, 2004 | 10:20 AM
ms1motorsports's Avatar
Try to tourqe the lugnut down so the actual stud will bite into the hub and hopefully will release the nut.
Old May 16, 2004 | 10:31 AM
JDMluvR's Avatar
Default Re: lug nut wont come off. pls. help ASAP (ms1motorsports)
I already tried that. It won't go anywhere, it will just keep spinning.
Old May 16, 2004 | 11:11 AM
civickiller's Avatar
pull on the tire and then try and take it off
Old May 16, 2004 | 11:55 AM
ham's Avatar
ham
whenever i run into that problem i take my impact and put it on the lugnut, pull up so its angled and zip it off. gotta pull up hard so it kinda holds it still. it rips the threads off with it. you will have to replace the nut and stud of course.
Old May 16, 2004 | 12:48 PM
4DRmafia's Avatar
Default Re: lug nut wont come off. pls. help ASAP (zcnos)
yea it happen to me once on the rear and it was a bitch to get off so what i did was took the cap off where to protect the big bolt to hold the hub on so i took that off then finally the whole wheel came off with the durm and hub ( looks funny ) then i take a torgue and melt the stud that was bad and replace it and i getting ready to replace all studs at once so less worry
Old May 16, 2004 | 02:02 PM
Riceburner247's Avatar
Default Re: lug nut wont come off. pls. help ASAP (civicsidude91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 &raquo;</TD></TR><TR><TD CLASS="quote">yea it happen to me once on the rear and it was a bitch to get off so what i did was took the cap off where to protect the big bolt to hold the hub on so i took that off then finally the whole wheel came off with the durm and hub ( looks funny ) then i take a torgue and melt the stud that was bad and replace it and i getting ready to replace all studs at once so less worry </TD></TR></TABLE>
Here, let me help you with that, " , . . "
Old May 16, 2004 | 02:03 PM
EL Vap133's Avatar
Default Re: lug nut wont come off. pls. help ASAP (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">
Here, let me help you with that, " , . . "</TD></TR></TABLE>
ROFL!!
Atauto
Honda CR-V & Element
12
Sep 22, 2015 09:52 PM
F20Cdriver
Oct 7, 2011 03:32 PM
shooitzlinh
Mar 20, 2005 06:44 PM
DOHClessEF-9
Feb 8, 2005 08:04 PM
sjteg
Jul 13, 2003 06:39 PM
