Engine problems HELP!!!
Old Nov 6, 2001 | 05:50 PM
vtec_outlaw's Avatar
Default Engine problems HELP!!!
I have a '86 Accord LXi winter beater and the problem is that when the temperature gets going the idle surges between 1200 and 1900 rpms. Has any one ever experienced this problem or have any suggestions? The dealer told me it might be the temperature sensor. Anyone know where this is located on the engine?
Old Nov 7, 2001 | 06:29 PM
BreakStuff's Avatar
New User
Default Re: Engine problems HELP!!! (vtec_outlaw)
Could be the temp sensor..
Could be the coolant level..
vacuum leak..
fast idle valve..
hmmm.. if it happens after the car is already warmed up.. I would have to think its the fast idle valve being its an LXI.. Did these things even have a fast idle valve?
someone help me out here please..
Old Nov 7, 2001 | 06:46 PM
BreakStuff's Avatar
New User
Default Re: Engine problems HELP!!! (BreakStuff)
Come to think about it.. coolant temp sensor could also be a culprit after the car is at normal operating temp..
What is happening is that your ECU is trying to find the proper idle range but cannot find the proper response from the involved sensors.. when this happens, the ecu will "hunt" for that unknown range and cause the idle to fluctuate..
Coolant Temp Sensor(TW) would also be a good place to start if the coolant level is ok..
It should be located where the upper radiator hose meets the engine cylinder head?, 2 pin connector.. note that the Thermal Switch is also located there and can be easily confused with the TW switch..
Old Nov 7, 2001 | 07:46 PM
976's Avatar
976
New User
Fast idle valve should be replaced or checked first.
beqa16v
Jan 2, 2007 08:34 PM
volkracing99
Jan 24, 2003 07:45 PM
Brandon Clifton
Dec 15, 2002 03:21 PM
Ri5e
Aug 25, 2002 08:23 PM
