ANYONE drive a prelude with bw 6 to 9 psi?
Old Nov 6, 2001 | 05:50 PM
freakie's Avatar
Default ANYONE drive a prelude with bw 6 to 9 psi?
I am thinking about turbocharging my lude but I hvae been told to be at only 6 to 9 psi of boost. If anyone is running that I have a question for you, can the stock injectors with maybe a piggyback computer flow enough fuel, perhaps with a bigger fuel pump only? what level is the injectors running at? I don't want the injectors to be running at 100% all the time as this might meana siezure adn boom of my engine...
so can stock injectors run enough fuel for 6 to 9 psi? anyone?
Old Nov 6, 2001 | 07:47 PM
fiyaboi's Avatar
New User
Default Re: ANYONE drive a prelude with bw 6 to 9 psi? (freakie)
u can run it with stock injectors if u r keeping it under 9psi.. i m running mine with 7psi and on occasions i boost it up to 9psi with no detonation or any problems. u would have to get a bigger fuel pump and an fmu or something like so. ur stock pump will not be able to handle it at boost.
Old Nov 6, 2001 | 10:28 PM
micrew's Avatar
New User
Default Re: ANYONE drive a prelude with bw 6 to 9 psi? (fiyaboi)
what are you running in the 1/4?????
Old Nov 8, 2001 | 08:36 AM
MEGA_BB6_Turbo's Avatar
Default Re: ANYONE drive a prelude with bw 6 to 9 psi? (micrew)
You can run up to 7 lbs. with the stock injectors. To fully boost at 8 lbs. you need at least a fuel pump. 9lbs. and a lil over u need the bigger injectors. I used to have problems before on my car because of the fuel cut due to the OBD. There is a way my mechanic bypassed it..buut i'm not really sure what he did ) . Also there is a device called the missing link which block any boost going through the oe sensor which should help u boost more. I have a 2000 Prelude soo this might not apply to ..lets say 97 or under maybe? The biggest problem i had was the fuel cut..but just inquire about it..and u should bypass it fine.
Old Nov 8, 2001 | 08:39 AM
Default Re: ANYONE drive a prelude with bw 6 to 9 psi? (MEGA_BB6_Turbo)
OH...btw...i dont have an fmax or a DRAG setup...it was all custom which is probably why i used to have the problems. I met a guy at an import showoff that had an f max kit on..and he said everything was fine and he boosted up to 14 lbs.? i'm not sure if it's true...but kool if bolt on kits do the job perfectly.
mattyv
Aug 11, 2009 04:41 PM
blackfoot
Jan 22, 2006 08:01 AM
yusoslo
Mar 23, 2004 01:54 PM
zip
Apr 22, 2003 09:07 AM
