fuel rail on b16a1
just picked up an r manifold....but unfortunately i have the 88-91 b16 which the fuel rail will not fit due to the location of the tps sensor...therefore i have to pick up 92+b16 fuel rail or 94+ teg and a few other that will fit like obviously the type r fuel rail...my question is are there any differences in these fuel rail performance wise...does anyone recommend aftermarket fuel rail such as aem,str,venom,vortech,etc....thanks
peace
peace
I think you mean its in the way of the IAT. The TPS is on the back side of the throttle body nearest the firewall. Check with the Honda dealership and Acura dealerships in your area. See if the Honda "long number" is the same from the different cars. Just an idea. If they have the same part number they are the same part. I believe the stock rails are good for up to 350 hp I thought I heard somewhere. What are your plans for the car? Do you need something where you would need large injectors and a huge need for fuel over stock? Other than show I don't think an aftermarket would do anything for you until you are force inducted.
[Modified by badCRX, 3:16 AM 11/7/2001]
