Torque Specs for Exhaust
Old May 16, 2004 | 12:07 AM
civicvtec1ps's Avatar
Default Torque Specs for Exhaust
Just need to get things straight before I install exhaust.
Torque Specs for 3 Bolts on Cat and Axle back for aftermarket exhaust systems.
If you use same specs as stock they are 25 lb-ft at the cat, 16 lb-ft at the axle. Correct?
The factory specs are irrelevant with an aftermarket cat back.
The axle joint on the stock exhaust uses spring tensioners and cone style gasket. Aftermarket uses standard bolts and flat exhaust gasket. 16 lb-ft is way too low.
Any thoughts on this?
Old May 16, 2004 | 10:08 AM
johnkimble's Avatar
good question...
honestly when i did my exhaust (spoon n1/t1r bpipe) 25ft lb's was about right on the cat. i hand torqued it a little bit past because it was leaking, but other than that it's doing fine. to the axle back i'm sure it doesn't matter TOO much, just be careful not to break the bolts, bend the flange, strip the threads, etc. i say just get it tight, not rattling, no leaking and you'll be fine.
good luck!
Old May 16, 2004 | 11:20 AM
Default Re: (johnkimble)
Yea.
I just want to do it at the first time right.
So I won't have to worry about any problems later on.
Any more inputs?
sohctodohc
11
Mar 26, 2007 11:21 AM
EG civic
Jun 27, 2006 09:29 PM
JimmyAtlantis
17
May 27, 2004 07:07 AM
KooK
May 29, 2002 07:33 PM
