Wiring a D series VTEC head (after mounting head on a Non VTEC block...)
how hard is it to wire everything up? I have the SOHC VTEC ECU -- should I get the wiring harness too? what do i gotta use, I'm not too good with electrical stuff.....thanks!
Well if you are using the p2p ecu, you are going to have to wire up the following:
Knock Sensor (need to buy one, ensure its obd2)
Vtec Selenoid
Vtec Oil Pressure sensor
You will also need to perform a 2 wire conversion for your IACV, which you will also need to puchase. If you do a search on this, you should be able to find one.
Chris
Vtec Selenoid
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote">No, you have to add the secondary o2 sensor wires to it, so not easier</TD></TR></TABLE>
you sure about that?
If he uses a 96-98 EX engine harness & the ecu, he wont' have to wire anything at all, everything is already integrated into the EX wire harness (2nd 02, VTEC solenoid & VTPS, etc).
The only problem I forsee is the P2P ecu looking for a knock sensor. Non-VTEC 96-01 blocks don't run knock sensor, but an EX engine does.
powerslide360, here's the wiring diagram for a 96-98 civic if you plan to reuse your non-vtec engine harness:
http://www.ff-squad.com/tech/w...8.jpg
and
http://www.ff-squad.com/tech/w...g.jpg
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">
Yes sir I am, had to do it myself, the o2 sensor is part of the dash harness on 96+ vtec civics
Wrong, he will have to add the second o2 sensor to it
Katman, I have the wiring harness with the SOHC VTEC head -- so I sould just wire it up like it was in the EX model? What happens (or will it happen) if the engine throws a CEL on me for the knock sensor?
**please...help me! Need to finish this project!
If I go by the diagrams with the DX (non VTEC) wiring harness, the pic of Plug A will fix the engine wiring completely?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerslide360 »</TD></TR><TR><TD CLASS="quote">Katman, I have the wiring harness with the SOHC VTEC head -- so I sould just wire it up like it was in the EX model? What happens (or will it happen) if the engine throws a CEL on me for the knock sensor?
**please...help me! Need to finish this project!</TD></TR></TABLE>
yes, if you have the EX engine harness USE IT. If you get a MIL code (23) for the KS, its ok, you can still drive around. Wire in the KS whenever you have the time to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerslide360 »</TD></TR><TR><TD CLASS="quote">If I go by the diagrams with the DX (non VTEC) wiring harness, the pic of Plug A will fix the engine wiring completely?</TD></TR></TABLE>
well, it will only fix the IACV, VTEC solenoid, and 02 sensor portion of the wiring; you would still have to wire in the VTEC Pressure switch in plug C, and the Knock sensor on plug D....if you plan to reuse a non-VTEC engine harness.
