Which hose is this (Skunk2 Intake Manifold)?
This is on a OBD1 B18C1. Currently I have it plugged up. I also have a hose coming off the crank <something.. forgot what it's called lol> just open (black box looking thing with two hoses attached to it under the manifold, not the secondary box.. below that). Not sure if that plugs into there (I'd need to extend the hose). No CEL's though and the car runs ok. Just wasn't sure what this hose was cuz I see it plugged up in every image I've seen so far of Skunk2 IM.
Also, sorry if this is your motor. I just did a search on HT and came across this one. Just let me know if you want me to take it down.
And if anyone was wondering, the install took me 8 hours. Yes, eight. 7 of those hours were scrapping off the old gasket. It did not come off worth ****.
Thing was baked on there so bad. My fingers are all blistered from scraping with a razer. I just kept scraping and sprayed WD40 on it as I went along. Tried brake cleaner too but WD40 seem to work better (got the gasket softer so it was a bit easier to scrape).
Modified by Eluzion at 6:55 AM 5/16/2004
Thing was baked on there so bad. My fingers are all blistered from scraping with a razer. I just kept scraping and sprayed WD40 on it as I went along. Tried brake cleaner too but WD40 seem to work better (got the gasket softer so it was a bit easier to scrape).Modified by Eluzion at 6:55 AM 5/16/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">goes to the pcv.</TD></TR></TABLE>
just like he said
just like he said
jkalex05
Aug 23, 2009 06:01 PM
99gs-r
May 27, 2003 11:47 AM
i 4
Nov 11, 2002 06:55 PM
