what is an "audio interrupt in lead" and other deck wiring questions
Old May 15, 2004 | 07:10 PM
7thGear's Avatar
Default what is an "audio interrupt in lead" and other deck wiring questions
just for clarity this is what i have
a bunch of wires hanging out of the hole in my dash cuz some jizz bag decided he shouldnt pay for his stuff... ohh well thats life for you
i have
power, battery, and ground,
2 front left, 2 front right
2 back left, 2 back right
thats what my old cdplayer used anyway, i also have 2 wires that are identical colour in the back that are not connected to anything ( there maroon with gray ) this is a 98 hatchback if it helps
the cd player in my lap ( donated by a friend) has everything the other connector does and also
1 wire for power antena... but i dont have that so its safe
1 wire for a remote... but again i'm ghetto
but now it has one wire thats labeled "audio interrupt in lead"... what is it? do i need it? my old cdplayer obviously didnt have one connected... any insight is appreciated
also in the plug itself i have an empty hole in a slot designated for "iLLumination" ( strangly spelled with two capital "L"'s... i have no wire for this.. just an empty hole
and so, i have 2 wires in my car that are identical and i have no clue what they do,
1 wire on the cdplayer that i dont know what its for, and one missing alltogether!
lets hit it....
Old May 16, 2004 | 05:29 AM
7thGear's Avatar
Default Re: what is an "audio interrupt in lead" and other deck wiring questions (7thGear)
morning bump...
i'ma start soldering today... so i better be right and none of this even matters..
Old May 16, 2004 | 06:22 AM
audioroach's Avatar
okay...the audio mute is not needed. Its there for any device
that needs to mute the radios audio ( navigation,cell phone)
just to give you a clue the wire code is EIA standard ( the radio is)
do a search for you oem wiring..and match it up with the EIA and your
good to go.
Old May 16, 2004 | 06:45 AM
7thGear's Avatar
Default Re: what is an "audio interrupt in lead" and other deck wiring questions (audioroach)
Old May 16, 2004 | 07:21 AM
Xsi's Avatar
Xsi
The audio interrupt wire is for muting your speakers when another device tells it to (usually a phone hands free kit etc). This is usually ground activated so if you want a mute button for your head unit you can put a switch between the ground and this wire.
The illumination wire is probably so your headunit dims its display when you turn the lights on, as it doesn't need to be as bright at night time.
Old May 16, 2004 | 08:54 AM
7thGear's Avatar
Default Re: (Xsi)
cool stuff
well i got the sucker in finaly, after blowing a fuse and not knowing about it... anyway ( thank god for haynes)
i have a small quirk tho... i thought i double checked the wires that were sticking out and those that stem from the deck and i thought i had them all figured out
but now my balance button switches between rear and front, while my fade button alternates between left and right... did i miss something here?
nothings blowing and everything is working, i dont have any back speakers yet but i will very soon,
is this a wiring problem or is the deck itself a little on the drinkie drinkie side?
EDIT: no ****... **** i'm a moron, hot showers sure bring insparation, i just messed up on the wiring, i have it thinking that my 2 fronts are actualy right front and right back....i'll sort it out when i come back... thanks for the info peeps!
Modified by 7thGear at 6:07 PM 5/16/2004
Old May 16, 2004 | 09:07 AM
Xsi's Avatar
Xsi
Sounds like you got your speaker wires mixed up, double check them.
Old May 17, 2004 | 06:02 AM
7thGear's Avatar
Default Re: (Xsi)
alright, i got everything wired right now, everythings soldered, nice and clean, got the pannels back on, wish i had a camera
thanks for the input.
btw how where does a 45watt unit stand in the grand scheme of things? ( i guess this is just for bragging rights, i probably wont get a sub but who knows)
Old May 17, 2004 | 07:18 AM
Xsi's Avatar
Xsi
Default Re: (7thGear)
45w head unit? not that great, depends on what brand because 45w Alpine is more than 45w Sony. You won't run a sub off that anyway.
Old May 17, 2004 | 09:55 AM
7thGear's Avatar
Default Re: (Xsi)
its an alpine unit
also i have 4 big wires sticking out the back that look like your typical sound jacks, but is that for the amps?
Old May 17, 2004 | 12:14 PM
integranation's Avatar
The wires you are referring to that are coming off the back of the head unit are probably RCA wires which are used for connecting amplifiers. And if you have four wires then you have two sets of RCAs.
As for the deck power being 45watts. This is generally rated at max power output and therefor you are only getting about half that much power going to your speakers all the time(RMS).
Old May 17, 2004 | 05:11 PM
7thGear's Avatar
Default Re: (integranation)
cool
ive been reading so much engine theory these past few years, got to get into this sound thing now... ahhh so much to read!
jdmed3
Audio / Security / Video
Mar 7, 2009 03:48 PM
GetawayInMoscow
Dec 24, 2006 04:34 PM
michoui16
May 4, 2004 04:35 AM
