Please, need part numbers
I am putting in a quaife in my 96 LS tranny and I need 10 of the ring gear bolts and two countershaft thrust washers. what are the part numbers?
you can probably buy them from http://www.acuraautomotiveparts.net but they dont list the pn's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">http://www.acuraautomotiveparts.org</TD></TR></TABLE>
I cant find them on that site
90017-689-000 BOLT, SPECIAL (10MM) [$3.26 x 10]
There's only one shim washer on the countershaft, located underneath the 1st gear. 23921-PK5-900 WASHER A [$4.28 x 1]
If you're talking about the 80mm differential shim, then you need to measure the clearance first before you know what thickness to order. Part numbers are listed in the service manual under the B18B1 differential section.
