timing belt. how much is too loose?
Old May 15, 2004 | 05:25 PM
JCracer723's Avatar
Default timing belt. how much is too loose?
ive done some search and i know the steps on how to do it..
BUT how much slack its ok?? ive read that been able to twist the belt on the cam sprocket and crank pulley side 90 degrees or 1/2 turn its ok... its this right?
been able to slip the belt off the cam sprocket with some minimum hand force sound ok? (new belt)
BTW this is a single cam .. d16z6 to be exact. i would ask on the eg forum. but there is absolutely no tech on that forum
Old May 15, 2004 | 05:36 PM
Project_ED8's Avatar
yea i would say the belt shouldn't twist more than 90 degrees. check your email i responded to it.
Old May 15, 2004 | 05:38 PM
Default Re: (Project_ED8)
oh yea one more thing. it sounds like u have the same problem i had. the t-belt was able to slip off with the cam gear with a little force and honestly i don't think it should be able to. now that i've re-tightened the belt properly...it doesn't come off if i put force on the belt and try to slip it off the cam gear.
JCracer723's Avatar
mine about twists 1/2 a turn ..
damn i try to tension the belt today.. and i wasnt able to loosen the damn tensioner bolt.. that thing its tight... i might overtighten it when i did it before..
Old May 15, 2004 | 06:22 PM
blah13's Avatar
Default Re: (JCracer723)
Be very carefull when tighening that tensioner bolt. I tightened mine big time bc it was a pain to get a tq wrench down there. A couple months later my tensioner slipped, took the belt off and most of the threads had been stripped in the block, most likely from overtightening. so just be carefull.
Old May 15, 2004 | 06:32 PM
JCracer723's Avatar
Default Re: (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">Be very carefull when tighening that tensioner bolt. I tightened mine big time bc it was a pain to get a tq wrench down there. A couple months later my tensioner slipped, took the belt off and most of the threads had been stripped in the block, most likely from overtightening. so just be carefull.</TD></TR></TABLE>
yep im afraid that happen
Old May 15, 2004 | 06:51 PM
blah13's Avatar
When it first happened my cams ended up pointing up so I got lucky. Went out and bought a new tensioner, when I took the old one off the bolt had 3-4 threads gone and the block had small pieces in the hole. So I just went to ACE, got a 30mm longer bolt, and put it back on.....bad idea. Thats why I'm now in the middle of pulling the motor out to re-tap the hole. Good luck.
realis9
Aug 26, 2007 12:52 AM
NoVALude
Jul 19, 2006 11:53 AM
-Gambit-
Nov 13, 2005 04:13 PM
JONBLAZE55555
Nov 9, 2003 12:27 PM
AdamITR
Aug 28, 2002 07:11 PM
