deck plated h22
Old May 15, 2004 | 05:19 PM
1700anddroping's Avatar
Default deck plated h22
this the problem.the intake manifold will hit the brake master cylinder,do you guys have any ideas as to what to do,i am stump on this one.i have herd of people turning them around"some one please explain that".
i just reouted the brake lines and it just barely missed,but now that i have a 5/8 ths deck plate,it will hit the brake master cylinder and i have run out of ideas.any and all help is appreciated.
Old May 15, 2004 | 06:34 PM
Default Re: deck plated h22 (1700anddroping)
any one have any ideas.
Old May 15, 2004 | 06:58 PM
boostedsol's Avatar
Try turning it around like you said, or else you might want to look at a custom intake mani, or maybe an aftermarket one that sits lower. good luck
Old May 15, 2004 | 07:01 PM
Default Re: deck plated h22 (boostedsol)
i already have a str pro drag manifold.but i do not know what they mean by turning it around.but appreciate the info.
Old May 16, 2004 | 06:30 AM
Sliced Beard's Avatar
by turning it around they mean the old hotrod and lowrider junk
you would have to create a cantilever and modify the hell out of your pedal assembly. By turning it around they mean install it to where the MC/BB is under the dash instead of in hte engine bay. I honestly would never do it. If I were you i would just modify the manifold a little bit in order to make it fit
Old May 16, 2004 | 07:58 AM
Default Re: deck plated h22 (dirtyd463)
there is no modifying the manifold ,and i knew they put it under the dash but i just cain't picture it and was hoping for some help .but i will fined the solution .i just have to keep thinking and searching,but thanks for your help.
Old May 16, 2004 | 08:33 AM
f@sth@tch89's Avatar
If this is a drag car I would suggest removing the brake booster to free up more room. Jeremy did it on his CRX and im going to assume his coupe. Im also considering do it on my 89 hatch to free up motre room w/ my b16 swap. Im also using the skunk2 mani, but it still feels crowded. I upgraded my fromt suspension to 90-93 integ. I feel confident I will be able to stop at the end of the 1320.
Old May 16, 2004 | 08:52 AM
Default Re: deck plated h22 (fasthatch89)
no this is not a tract car althought the set up is with out a doubt full race and then some.this is a street car.i have thought about doing that "removing the brake booster,that means my pedal will be stiff as hell,other than that i don't see any other problems do you?????.
elochai9790
Jan 23, 2010 07:34 PM
pythoner
Suspension & Brakes
Sep 3, 2008 04:01 PM
jikespingleton
Jan 2, 2007 01:31 AM
psileepR
Aug 21, 2002 09:31 AM
