Question about brakes
Old May 15, 2004 | 03:31 PM
b18cu's Avatar
Default Question about brakes
My question is, can itr front and rear brakes both be put onto a gsr?
I think I have seen brackets made for the fronts to be put on with, but I have no dea where I could buy these such brackets. Are brackets like these made for the rears as well?
So if anybody has any info where i could find what I'm looking for let me know?
thanks...
Old May 15, 2004 | 03:34 PM
TIRENECK's Avatar
Default Re: Question about brakes (b18cu)
so you want to only swap brackets? anything from the type R would botl on to a DC but front knuckles gonna diff axles if 5lug.
Old May 15, 2004 | 03:37 PM
b18cu's Avatar
Default Re: Question about brakes (TIRENECK)
?...i want irt calipers to fit onto my gsr...they don't directly bolt on...
Old May 16, 2004 | 07:22 AM
trellix78's Avatar
New User
ITR calipers cannot directly fit onto GSR caliper brackets.
You'd need the ITR brackets (they fit on the GSR knuckle) and then
fit the ITR calipers onto that.
You'll also need ITR-sized 4-lug rotors. I'm not sure if anybody makes those.
Old May 16, 2004 | 08:26 PM
b18cu's Avatar
Default Re: Question about brakes (trellix78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trellix78 &raquo;</TD></TR><TR><TD CLASS="quote">ITR calipers cannot directly fit onto GSR caliper brackets.
do you know who makes the brackets...?
you can get rotors redrilled 4x100
Old May 19, 2004 | 03:00 PM
trellix78's Avatar
New User
get the stock brackets that the calipers bolt onto
they bolt right up to the GSR knuckle
redrilled rotors should work
Old May 19, 2004 | 03:41 PM
Katman's Avatar
check out http://www.FASTRBRAKES.com.
Brian sells mount kits for what you're trying to achieve (ITR brakes on a GSR). He also sells rotors for this type of application too.
Old May 20, 2004 | 08:28 PM
b18cu's Avatar
Default Re: Question about brakes (Katman)
ya itr calipers on a gsr...any idea how much that would run me?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">check out http://www.FASTRBRAKES.com.
Brian sells mount kits for what you're trying to achieve (ITR brakes on a GSR). He also sells rotors for this type of application too.</TD></TR></TABLE>
dose this guy have a email?
V-SPEC 1
Apr 2, 2007 10:29 AM
BanEL
Feb 28, 2007 09:36 AM
92integra-R
Dec 11, 2006 08:29 PM
pbomers
May 9, 2004 04:34 PM
Garrett
May 3, 2004 09:29 AM
