code 1 on my b16 motor
can anyone tell me what code 1 is and how to fix it? I just got it all wired up and tried to start it up the other day and i get nothing (not even a click from the starter) please help
Starting problem has nothing to do with code 1. Code 1 is a miswired or not plugged in o2 sensor. For your starter problems check the black wire on the starter solenoid. It is easily pulled off while fiddeling with other things. If its on nice and tight check fuses. If fusues are good take a test light and have someone key ignition the starter. You should have 12v when the ignition is put in start. If its not there then you got some wires to track down. If you have 12v it may be a bad starter.
poprocksncoke
Feb 10, 2014 03:07 PM
91efbluehatch
23
Nov 14, 2011 11:12 PM
