B16 swap in EG crooked...
Old 05-15-2004, 01:25 PM
gsl_05's Avatar
Default B16 swap in EG crooked...
I just installed a B16a in my EG, however to motor sits crooked. I'm using Integra B series motor mounts, are these the wrong mounts? The drivers side is a couple of mm off, while the passenger side is sits slightly lower than the right. What can I do to fix this? Any info. would help. Thanks
Old 05-18-2004, 07:54 AM
tencan's Avatar
Default Re: B16 swap in EG crooked... (gsl_05)
Can you provide pictures..?.. It will be a little easier to help you out.
Old 05-18-2004, 12:02 PM
diycx's Avatar
Was the EG an automatic? If so, the passenger side bracket (on the body) might be located higher than on a manual car. I had the same problem with my teg. You can get a new bracket from the dealership and have it welded on or use a longer high grade bolt and some washers to lower that side. Good Luck
Old 05-18-2004, 09:17 PM
gsl_05's Avatar
Default Re: B16 swap in EG crooked... (diycx)
Here are some pics:
It is a first gen. B16a Jap Spec OBD 0 with a hydro to cable conversion. The mounts are stock from the motor, but there is no way those are the correct mounts. Any info would be helpful. thanks
Old 05-19-2004, 12:39 AM
blackANESE's Avatar
Your car may have been in an accident and bad repair work???
Old 05-19-2004, 08:39 AM
gsl_05's Avatar
Default Re: B16 swap in EG crooked... (blackANESE)
NO accident, the D15 in the car prior to the swap was straight. I'm thinking wrong mounts, but do not know which ones to use. A friend suggested using the old D series mount on the driver's side. Would that work?
Old 05-19-2004, 02:33 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsl_05 &raquo;</TD></TR><TR><TD CLASS="quote">Here are some pics:
It is a first gen. B16a Jap Spec OBD 0 with a hydro to cable conversion. The mounts are stock from the motor, but there is no way those are the correct mounts. Any info would be helpful. thanks </TD></TR></TABLE>
that looks like a civic upper drivers side mount to me. I thought you said you were using integ b mounts?
Civic2Fast
05-23-2008 07:55 AM
ALL MOTOR DA
04-21-2007 06:13 PM
dblock
05-09-2006 06:08 PM
zbaber
03-12-2006 10:03 PM
HATCHingMN
14
05-23-2004 09:31 PM
Quick Reply: B16 swap in EG crooked...
