Inline Pro Manifold and Tial 38 MM Wastegate...will it fit?
Hey, just got my tial wastegate from b18bturbo
...now by looking at the manifold, it seems like the wastegate sits just on top. Will I be able to close the hood with no problem or will I need to get an elbow for the wastegate?
i don't know how much bigger the 38mm is to the 35mm in physical dimensions, but i've got the 35mm and the inlinepron mani. i haven't had any problems with the hood closing. hope this helps.
Looke from underneath the car and close it gently, if you slam it, you may put a nice sized dent in the hood and that would really suck.
I know that some civics have problems with that fitting clearing to hood. I've seen a few pictures now with the famous pea sized dent in the hood
I'm going to see if mine clears as soon as the rest of my turbo toys get here and everything starts to go on the car. But just in case, I have one of those elbows. The only drawback to that is that you can't run a dumptube and the blown off exhaust gas just goes wherever.
Just something to think about.
it will clear, but if have a civic (which you don't) the top brass fiitting for an EBC will hit the underside of the hood
digitalVinyl
Mar 8, 2007 01:54 PM
OshkyCiv23
Sep 23, 2005 10:11 AM
