WHAT do i have to do to get my jackson racing supercharger to run correctly?
Okay, my check engine light is STILL ON and my idle is still fluctuating up to 1000rpm. If you didn't read my last posts, my check engine light was on because of my knock sensor, and Idle air control, and i replaced BOTH of those, and got a new throttle body. My idle is at it AGAIN, fluctuating like there's no tomorrow. The car runs AWESOME and is very quick, but when you come to a stoplight, the idle is terrible, and my exhaust is sounding a little funny too. Does anyone have any suggestions or answers?
Info: 99 Honda Civic EX D16Y8
Edelbrock throttle body
Edelbrock headers
Jackson Racing Catalytic Converter
Jackson Racing Supercharger
K&N typhoon Intake
Dynomax Exhaust
New O2 sensor, Knock Sensor and Idle air Control valve/motor
Edelbrock headers
K&N typhoon Intake
Dynomax Exhaust
Has the idle been fluctating since you installed the charger? Most likely a vacuum leak, either a hose was misplaced, slit open, the charger needs retorqueing to the manifold, you didnt get the blower gasket on right, etc.
there was a vacuum leak, but there isn't anymore. The supercharger IS the intake manifold, it's all one piece. I have a jackson racing fuel pressure regulator that came with the supercharger, that's it
Do u have a line running from ur sc to ur valve cover? kinda like a cold air intake has a line running from it to the valve cover. Or do u just have a filter on it?
prjctwhteg
Nov 16, 2009 10:56 AM
edelbrock99CivicEx
May 9, 2004 10:43 AM
