ECU immobiliser?!
Ok, i recently done a b16a2 conversion into a 99 coupe. Was formerly an Ls (d16y7), the problem i am having now is the ECU immobiliser (the crappy black box inside the steering column), because the ECU does not match the key, the injectors will not inject any fuel in. Is there anyway around the immobiliser or anyway to "trick" it?
I know that a JDM ECU does not have this immobiliser feature, so in getting a JDM ecu it would sort it, but i can't find any JDM ecu's for a decent price....
Thanks in advance...
I think hondata can disable that feature, but I think you have to get their whole ecu package. Depending on how accomodating your local honda dealership is, they may be able to make you a key that would work.
maor_bz
Jun 6, 2016 06:41 AM
