How Would a Bad OBD1 Distributor Act With No CEL Code, or Is It Possible?
Old May 15, 2004 | 04:08 AM
ruby civic II's Avatar
Default How Would a Bad OBD1 Distributor Act With No CEL Code, or Is It Possible?
I am stuck with a weird electronic issue as I have obd0 to obd1 conversion in a car that ran fine before with only a steady blinking CEL but NO code.
New distributor wired as per manual
Injectors getting fire and they were not changed and have resistor box already
Timing and Spark plugs plus wires OK
Ran all the dizzy wires and injector wires back thru the jumper harness to ECU and all are correct
Car will occasionally act like it is going to start and then hold a less than 500 rpm idle but not respond to gas pedal input and then die after 2-3 seconds of this sickly running.........
Any ideas?
Old May 16, 2004 | 07:49 PM
Default Re: How Would a Bad OBD1 Distributor Act With No CEL Code, or Is It Possible? (ruby civic II)
ttt. i do need some help in figuring this out as the manual doesn't say jake about this
thanks, all
Old May 30, 2004 | 08:50 AM
ttt, i have been getting a lot of feedback on bad igniters, what do you all think?
i guess i will try to get ANOTHER dizzy and see since i can not find any obd1 vtec cars to test my unit on...
Euphorex
Oct 24, 2014 08:30 PM
Ash J. Williams
Dec 24, 2012 01:02 PM
efdxjdm
13
Sep 12, 2009 04:23 PM
Ruby Civic
Mar 11, 2004 09:08 PM
91civicEX
15
Sep 3, 2003 10:33 PM
