VA: Reconditioned .030" Milled LS head with 0 miles
I just milled my old head at work today. i took it all apart and cleaned everything up.
had 129xxx miles on it. now has 0.
blasted the valves
machined the valves
machined the valve seats
tumble cleaned the springs and retainers
milled the head .030" should raise the compression roughly .3 points
only thing not changed was the seals. if you send me some i will gladly change them for you for $25 more
definately comes with cam caps. missing one cap bolt though
asking 250.
I also have the IM, Fuel rail, cams, and gears too
blasted the valves
machined the valves
asking 250.
