car won't start need help
Old May 14, 2004 | 06:23 PM
blkwidow420's Avatar
Default car won't start need help
I just put a b16 in my civic and now it won't start. I need some ideas on what it could be. I had a b16 in there allready and just put a new one in. I instatled a new timing belt but I checked the timing 3 times before I dropped it in so it should be right. I also syphoned out the old gas( it sat for 6 months). I checked and the spark plugs are firing and are new. No check engine lights. It doesn't even try to start just cranks and cranks. Distributer was taken off so that need to be timed but I have to start it first. Checked the compression and its 200psi on all four.
I need Ideas. If the timing belt jumped would there be compression???
Old May 14, 2004 | 07:15 PM
Default Re: car won't start need help (blkwidow420)
to the top
Old May 14, 2004 | 07:23 PM
someone help
Old May 14, 2004 | 07:45 PM
sporkcrx's Avatar
Is the distributor on right and not 180 degrees off? Plugs are getting spark when it's cranking? Fuel pressure?
Old May 15, 2004 | 09:55 AM
Default Re: car won't start need help (sporkcrx)
distributer is on right I allready checked this, There is fuel presure because I can smell gas and I pulled the plugs and they were wet.
Old May 15, 2004 | 12:40 PM
BUMP
Old May 15, 2004 | 01:39 PM
sporkcrx's Avatar
Sounds like it's not firing if they're wet.
Old May 23, 2004 | 06:23 PM
Moon Ill's Avatar
So you saying that if spark plugs are wet, then the car is not firing. Mines cranking and not starting as well. (1990 CRX DX)
Old May 24, 2004 | 02:35 AM
civickiller's Avatar
Default Re: (Moon Ill)
do a compression test, if you got compression and spark and fuel. then eitehr yoru timing is off, or your wires or injectors arent in the right order
Hondaguy83
Dec 5, 2012 05:21 PM
gowenburnett
May 30, 2011 05:20 PM
bestcivic
Aug 11, 2009 08:20 AM
92accordjohn
Mar 20, 2008 05:45 PM
