starter spiining motor not flywheel looks good
Old May 14, 2004 | 06:19 PM
cstay's Avatar
Default starter spiining motor not flywheel looks good
If i turn the key the motor seems to turn over a little bit then the starter just starts singing. I turnd the motor over like a 1/4 turn and it did the exact same thing thinking maby the teeth on the flywheel are gone. took off the starter the the teeth look fine on both the flywheel and the starter. then i took apart the starter and all of the gears bushings and berrings in there look fine. could the cog just be like slipping on the starter shaft?
Old May 14, 2004 | 06:27 PM
Sliced Beard's Avatar
Default Re: starter spiining motor not flywheel looks good (cstay)
sounds to me like the bendix gear is messed up on your starter
Old May 14, 2004 | 06:30 PM
cstay's Avatar
Default Re: starter spiining motor not flywheel looks good (dirtyd463)
well i am gona try another starter tommrow i have a auto one that im gona swap the mounting plates with and try it out and se what happens.
G60
Oct 13, 2020 12:58 PM
dmanfree
Jun 21, 2013 12:38 PM
FroMan
Sep 5, 2009 04:57 PM
GoneImport
Feb 18, 2008 06:45 AM
MikekiM
Jan 18, 2005 09:47 AM
