alternator clearance in b16 crx
Old May 14, 2004 | 04:55 PM
Chronic_SMOKE's Avatar
Default alternator clearance in b16 crx
ok i have an 88 crx with a b16a. i was having transmission problems so i bought another cable tranny. me and a friend swap trannys, and everything goes cool. When everything is finished i test drive the car, all the gears are working, transmission seems fine. but i am hearing a very strange noise so i come back home to check everything out. then i notice that the alternator pulley is scraping against the frame. this is strange because when we did the motor swap we made clearance for the alternator and everything was cool before we put this tranny in.
im thinking that i should pull out the motor and make the extra clearance that i need. if anyone has some info or advise let me know thanks.
Old May 14, 2004 | 05:50 PM
0554's Avatar
get a smaller belt and then you can pull it forward slittle and it will give you more clearance.
Old May 14, 2004 | 06:40 PM
Sliced Beard's Avatar
Default Re: (88crex)
where is the BFH when you need it
or you can just install a shorter 4-rib belt like previously suggested
Old May 14, 2004 | 08:32 PM
doublejz's Avatar
Default Re: (dirtyd463)
hammer my buddy had the same problem, just got the hammer out and made more room for the alternator
Old May 14, 2004 | 09:56 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (doublejz)
I used the stock D series alt. and it works fine. Much cheaper to replace and really easy to take in and out. Sometimes I wonder if it puts out enough power tho.
Blaze
Old May 14, 2004 | 10:16 PM
DC 2's Avatar
Default Re: (Blaze45)
I ended up beating my frame rail before the swap. Try a smaller belt like said before.
Old May 15, 2004 | 06:18 PM
Default Re: (EH3B18B)
ill try using a smaller belt. thanks for the help
Old May 16, 2004 | 12:25 PM
TTT any more info on the d series alternator onn b series motor????
esford90
Mar 25, 2010 07:25 AM
SomeDude56
Apr 3, 2006 05:59 PM
rhetorical
Oct 13, 2004 02:39 PM
chirp2hrd
Oct 7, 2002 03:54 AM
djay86
11
Aug 20, 2002 07:36 PM
