ABS brake system to NON abs in 3rd gen Teg, anyone know how?
Old May 14, 2004 | 03:52 PM
GeorgeJetson's Avatar
Default ABS brake system to NON abs in 3rd gen Teg, anyone know how?
I hate ABS I dont want ABS and it buncheds up the engine bay, anyone done or know how to do it? Please share your stories. Thanx
Old May 14, 2004 | 08:34 PM
patmcd's Avatar
Default Re: ABS brake system to NON abs in 3rd gen Teg, anyone know how? (georgejetson)
Im assuming all that incoherent babbling ment you want to remove your abs. Yes it can be done and this topic has been covered many times. Why dont you try the handy little search button
Old May 15, 2004 | 05:51 PM
Default Re: ABS brake system to NON abs in 3rd gen Teg, anyone know how? (patmcd)
I tried the ******* searh button, I type ABS, ABS removal, Integra ABS, I didnt find ****.
Old May 15, 2004 | 06:17 PM
Jericho's Avatar
If you have a 94-95 Teg I think you can disable it if you pull the ebrake up until the light comes on and drive it a little. To turn it back on you have to restart the car. I read that somewhere on TI.
Old May 15, 2004 | 06:28 PM
Default Re: ABS brake system to NON abs in 3rd gen Teg, anyone know how? (Jericho)
I want the whole systme removed from the engine bay.
Old May 15, 2004 | 08:42 PM
IntEGNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jericho &raquo;</TD></TR><TR><TD CLASS="quote">If you have a 94-95 Teg I think you can disable it if you pull the ebrake up until the light comes on and drive it a little. To turn it back on you have to restart the car. I read that somewhere on TI.</TD></TR></TABLE>
ive read that as well.
Old May 15, 2004 | 09:02 PM
m R g S r's Avatar
Default Re: ABS brake system to NON abs in 3rd gen Teg, anyone know how? (IntEGNYC)
Or...You could just pull the abs motor fuse out.
And BTW you suck at searching!
https://honda-tech.com/zerothread?id=667338
Came up with 12 total, and I barely tried.
And here, just because I feel bad for you:
You will need from a 1994 Integra RS
Prop Valve
4 front hard brake lines
RS master cylinder and brake booster (15/16)
Krusty_the
Mar 28, 2009 04:01 PM
500hpintegra
Nov 8, 2006 06:09 PM
bracket 4 life
Jan 2, 2004 06:31 AM
JasonNagra
Mar 17, 2002 03:10 PM
DC5 Type-R
Mar 8, 2002 05:52 PM
