Speedometer drive after swap?
Old May 14, 2004 | 03:38 PM
JohnnieChimpo's Avatar
Default Speedometer drive after swap?
Just trying to tie up some loose ends.
89 CRX HF w/95 GSR engine + cable GSR trans.
The trans didn't come with a speedometer drive.
What do I use to plug my speedo cable into?
Will the one from my HF trans fit?
Old May 14, 2004 | 06:19 PM
FourthGenHatch's Avatar
Default Re: Speedometer drive after swap?
Your cable won't go into the tranny? Make sure there isn't an electronic vss in the hole for the cable since I suppose GSRs were electronic vss.
Old May 15, 2004 | 05:28 AM
Default Re: Speedometer drive after swap? (JohnnieChimpo)
When I bought the YS1 trans it was bare. There is a hole in the case where an electric or cable speedo drive goes. Which speedo drive do I use? Will the one from my CRX work or do I need one from an Integra?
Old May 15, 2004 | 08:35 AM
Karterguy13's Avatar
I used one from an ls on mine and plugged the power steering lines. I believe your stock one works though.
Old May 15, 2004 | 11:46 AM
crx_88_si's Avatar
Default Re: Speedometer drive after swap? (Karterguy13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karterguy13 &raquo;</TD></TR><TR><TD CLASS="quote">I used one from an ls on mine and plugged the power steering lines. I believe your stock one works though.</TD></TR></TABLE>
try the stock HF, if it fits then use it
Old May 15, 2004 | 11:52 AM
fourthgenhatchB17's Avatar
Default Re: Speedometer drive after swap? (crx_88_si)
My D series one worked perfect in my B series cable trans. Looks a lot cleaner than the b series one.
Old May 15, 2004 | 02:36 PM
Default Re: Speedometer drive after swap? (fourthgenhatchB17)
Thanks guys.
90 integra da
Transmission & Drivetrain
Mar 11, 2013 04:32 PM
goldenhatch13
19
Nov 10, 2008 05:49 AM
goldenhatch13
Nov 8, 2008 02:04 PM
coot_er
13
May 25, 2004 07:02 PM
Mr Furball
Aug 13, 2002 07:21 AM
