Ghetto build diary
Old May 14, 2004 | 03:24 PM
menkio's Avatar
Default Ghetto build diary - 16y7
may 14th.
Ls rods from bspec18 $48 :done :
arp fasters, head bolts - lighten motorsports $30 & 80 :done:
y8 intake - $50 :done:
y7 head, pnp, intake port matched, head portmatched $40-50 :done:
fidanza flywheel - $180 :done:
obd2a to obd1 harness $85
po6 chipped to p28, zif socket, $100
uberdata $free
bore/hone/clean/resurface - aim motorsports $125
bottom end balanced and blueprinted - aim motorsports $100
dh-racing crank pully $125
dizzyking dizzy $200
homemade grounding kit $free
y8 head gasket $49
n12 re-ground camshaft little bigger than exospeeds stage1 $210
used adjustable camgear $40-60
Pistons...
right pistons guys ???
acuraautomotiveparts.org
7664 RING SET (OS 0.50) $27.98 $111.92
7739 PISTON (OS 0.50) $38.53 $154.12
d16a6 right ? from the 88 integra, 3door ls. ka5mt.
head is almost done minus having the cam put in, valves adjusted, and cleaned up.
I think next is order the pistons, and have the block work done by the end of the week. I'll put up some pictures in the next couple nights.
btw this is a d16y7.. lol sorry
Old May 14, 2004 | 03:34 PM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: Ghetto build diary - 16y7 (DewMota)
cool, keep us updated
Old May 14, 2004 | 03:36 PM
menkio's Avatar
Default Re: Ghetto build diary - 16y7 (JDM EK9)
you know if thoose are the a6 pistons ?
Old May 15, 2004 | 03:17 PM
menkio's Avatar
ok, did'nt find out its 88-91 crx si, for the d16a6.
now.. what do i need, i have ls rods, arp fasterns, i ordered the pistons and rings.. what about the wrist pin, can i re-use my y7, do i order new pins, also.. when i have the crank balanced and the bottom end balanced.. do i replace the bearings..
the block only has 35k on it
rpmraper
10
Jun 12, 2011 08:25 AM
maxwellmercer
Dec 9, 2009 11:58 AM
Pazzio1
May 8, 2006 08:08 AM
ServiceAdvisor
11
Jul 7, 2005 06:23 PM
homeskillet
Jan 12, 2005 01:13 PM
