cant get my F'in altenator out. 90 civic hb
Old May 14, 2004 | 10:36 AM
7808's Avatar
Default cant get my F'in altenator out. 90 civic hb
i got the fukin thing just sitting in there and i dont see a way to pull it out without romving the brake fluid master whatever the hell or taking it out through the bottom if i remove the oil filter... maybe.
am i just retarded?
theres gota be a fast way..
90 civic hatch /d15b2
Old May 14, 2004 | 10:39 AM
manson's Avatar
Default Re: cant get my F'in altenator out. 90 civic hb (fuctup)
never taken one out on a d series, but you shouldn't have to do all that.
go buy a helms...
Old May 14, 2004 | 10:40 AM
7808's Avatar
Default Re: cant get my F'in altenator out. 90 civic hb (mansonteamsmyt)
...thanks
Old May 14, 2004 | 10:46 AM
kylefakesi-r's Avatar
pull the axle. come out through the bottom.
Old May 14, 2004 | 10:47 AM
APEX CRX's Avatar
I was able to get mine out the bottom. you do have to turn the damn thing a few times to get it just right but once you do it'll drop right out. If not you might have to loosen the lt radius arm?
Old May 14, 2004 | 10:49 AM
RobbieG35's Avatar
12 Years Strong
Default Re: cant get my F'in altenator out. 90 civic hb (APEX CRX)
Got mine through the top. JDM B16, ITR intake manifold, had to take out the fuel rail
Old May 14, 2004 | 10:52 AM
Mr_CRX's Avatar
Default Re: cant get my F'in altenator out. 90 civic hb (HybridHatch88)
I got mine out through the top. You shouldnt have to take your axle off or anything.. You said you have a d15b2. I had the same engine in my crx. I pulled it out from the top, to the left of the intake manifold. Take off the intake arm. You will also have to push some coolant hoses out of the way. I didnt need to take them off, just bend them.
It took a little bit of thinking and a little bit of muscle to wiggle it out of there. I havent done it in a while, but hopefully that will help give you an idea.
Old May 14, 2004 | 11:06 AM
7808's Avatar
Default Re: cant get my F'in altenator out. 90 civic hb (Mr_CRX)
thanks for the help.
this is ****** stupid.
Old May 14, 2004 | 11:32 AM
7808's Avatar
i had to take like 2 coolent hoses and move some **** but after a bunch of swearing and chain smokin i got the ****** out the top.
thanks guys
baked_beanz
Jun 3, 2005 09:55 AM
elrandeeto
May 24, 2005 08:03 PM
