Compression test results too low? - b16a2 with 9.4:1 CP
Old May 14, 2004 | 08:22 AM
Hoodwinked's Avatar
Default Compression test results too low? - b16a2 with 9.4:1 CP
Alright, my motor makes a lot of noise, like piston slap even when the motor is fully warmed up, I thought maybe the rings didnt seat properly. So, my question is are these compression numbers too low for a 9.4 compression ratio, stock head. I got 125 across the board. The person who did the test said it should be around 160 with that compression ratio. Did the person who installed my pistons mess up and hone the cylinder walls too much? What gives?
Old May 14, 2004 | 08:26 AM
vaporboy12's Avatar
could be some bent valves
vaporboy12's Avatar
pour some atf in there and see if the number go up
Old May 14, 2004 | 08:28 AM
VisualAutoMotoring's Avatar
Default Re: (vaporboy12)
125 is lil low...do a compression check or leakdown
GEN2 LS
12
Sep 29, 2009 10:43 AM
88 civic
Apr 5, 2009 03:21 PM
Z32Z06
Honda S2000
Feb 8, 2006 04:59 PM
builtprelude
Jan 22, 2004 10:49 PM
