b16 swap help with VSS and some other plug
i did a b16 swap with my Hf. i found most of the wires to be plug and play. but i can't find out what plugs into the vehicle speed sensor. also there is some other plug on the wiring harness that doesn't plug in to anything. i don't think that it is my VSS because it doesn't plug in to it. if it helps it looks like it has 3 hole in the plug that are in a straigh line.
also how many quarts of tranny fluid does a b16 hold? i think its 2.2?
pin B16 on ECU is your VSS....should already be there. the extra plug i believe you dont use, Controlled some valve on the D15 motor. you fill tranny on a level surface till tranny fluid(oil) trickles out of fill hole.
im not talking about were it plugs into the ECU im saying that the grey thing on the top/back part of the tranny has nothing to plug into it.
If you're talking about the VSS that came with the B16 tranny...that's an electronic VSS and it wont work unless you replace your cluster with a jdm SiR...you need a B series cable VSS (which i have one for sale btw) or you can try swapping your stock VSS and see if it works...
91teg
Apr 24, 2008 04:57 PM
user 72830283
13
Sep 18, 2005 12:20 PM
grante
May 2, 2004 05:36 PM
