head gasket and....
Old May 14, 2004 | 07:07 AM
spaceman's Avatar
Default head gasket and....
when replacing the head gasket for an old b16,what else should be changed while im at it,any special seals or anything?
Old May 14, 2004 | 07:27 AM
tgreaves's Avatar
Default Re: head gasket and.... (spaceman)
Since you have the head off you might want to replace the valve seals depending on the mileage of the engine.. Also why not replace the timing belt and water pump while your in there..
Old May 14, 2004 | 08:28 AM
spaceman's Avatar
Default Re: head gasket and.... (tgreaves)
anything else?..on the b16 is there an oil jet like the older d motor?
Old May 14, 2004 | 09:33 AM
tgreaves's Avatar
Not that I know of..
Old May 14, 2004 | 10:56 AM
Ekasey's Avatar
valve cover gasket too but agreed with above water pump timing belt, and valve seals if needed
Old May 14, 2004 | 10:59 AM
wickedEFguy's Avatar
Default Re: head gasket and.... (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">valve cover gasket too but agreed with above water pump timing belt, and valve seals if needed</TD></TR></TABLE>
don't forget the valve cover gromets under the valve cover where the sparks go
Old May 14, 2004 | 11:14 AM
tgreaves's Avatar
Default Re: head gasket and.... (wickedEFguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">
don't forget the valve cover gromets under the valve cover where the sparks go</TD></TR></TABLE>
Good point.. And dont put those things in backwards, Its a PITA I know..
Old May 14, 2004 | 12:09 PM
spaceman's Avatar
thanks doods
redturds
Honda Civic (2001 - 2005)
Sep 5, 2018 08:41 PM
deerman2701
Feb 1, 2013 05:33 AM
Happs
Jan 26, 2009 12:06 PM
snouka
Mar 26, 2006 10:05 AM
typeR#0427
Mar 31, 2005 10:26 AM
