AC/Power Steering ROBBING HORESPOWER???
Old May 14, 2004 | 04:39 AM
Hatch It's Avatar
Default AC/Power Steering ROBBING HORESPOWER???
My car doesnt have power steering or Air Conditioning. Does this really help out on HP? I heard it does and saves ALOT of weight, just curious what you guys think about how it weighs.....
Later
Old May 14, 2004 | 04:40 AM
Jimmy's Avatar
Global Moderator
It saves weight.
I was always told that the AC wasn't taking horsepower untill you turned it on?
Old May 14, 2004 | 04:47 AM
SOHC_MShue's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">It saves weight.
yes that is correct. Power steering does however take away your hp because it is always on. You will feel a noticable gain by removing power steering...i did anyways. I have seen dynos of it making 3-6whp and that is everywhere in the powerband...not just peak hp or anything.
Old May 14, 2004 | 04:48 AM
Hatch It's Avatar
Default Re: (Jimmy)
But its still an extra belt running off the motor, right now I have elcetric fans, no AC and no PS so there isnt anything running off the motor but the alternantor. you get what im saying? Im just wondering if its a huge difference......
How much weight is removed by taking all that out?
thanks for the quick response....
Old May 14, 2004 | 06:52 AM
degooser's Avatar
Default Re: (Cons94)
taking out ac maybe 40 - 50 maybe..thats everything the compressor, fan all the lines the condenser box but i could be wrong or really weak...i had to lift all that **** in a couple boxes a few weeks ago..
ps is pretty much the pump and the reservoir so its not much in the weight department..
Old May 14, 2004 | 08:56 AM
Padawan's Avatar
Darth ModerVader
Default Re: (degooser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser &raquo;</TD></TR><TR><TD CLASS="quote">ps is pretty much the pump and the reservoir so its not much in the weight department..</TD></TR></TABLE>
About 16 lbs. on an Integra - should be basically the same on Civics. Incidentally, this is also the same amount of weight I saved with a FiberImages C/F hood.
ray.riddler92
May 24, 2011 06:08 PM
4FoRaLL
14
Apr 4, 2005 10:49 AM
nwarp
Jul 29, 2002 08:10 PM
ITR#203
Apr 24, 2002 05:38 AM
