question about antenna wire; head unit removal
Old May 14, 2004 | 03:33 AM
CrazyModGSR's Avatar
Default question about antenna wire; head unit removal
I am taking my Kenwood cd player out of my 'teg and was wondering where the antenna wire is located? There is an a special plug that was put into the back of the deck when it was installed (by Tweeter), and the other end of that plug is connected to the antenna wire. However, I can't see where the antenna wire goes after it goes under the carpet. Is it necessary to remove the entire carpet to find it's source? Lastly does the end of the stock radio wire have some sort of jack (looks like a headphone or even rca jack) or is it a harness or what?
Thanks much
Old May 14, 2004 | 08:33 AM
nickgmiller04's Avatar
Default Re: question about antenna wire; head unit removal (CrazyModGSR)
when i put in my alpine deck, the antenna wire is a larger thick black wire w/ like a metal probelike thing that plugs into its own hole, separate from the rest of the wiring.
just unplug all the wires from the deck, and take it out. you dont need to pull the whole wire out... or go under the carpet.. elaborate some more if i didnt answer the ?
Old May 14, 2004 | 08:39 AM
steven975's Avatar
Default Re: question about antenna wire; head unit removal (nickgmiller04)
the antenna is separate from the main harness.
all you have to do is wire the radio to the custom Honda Harness, plug in the harness to the car and connect the round antenna wire. that's IT!
Old May 14, 2004 | 10:21 PM
Default Re: question about antenna wire; head unit removal (steven975)
got it. found the probe-like part of the antenna wire, just hidden. thanks again
Black99GSR
Apr 30, 2007 06:36 AM
TurboEM1
Dec 7, 2005 09:27 AM
ef-hatchcrap
12
Aug 4, 2005 11:37 AM
Slvr_CRX
Feb 23, 2005 07:27 AM
OuNcE
Audio / Security / Video
Sep 21, 2003 04:14 PM
